engine light on and car sputtering in idel
Old Mar 18, 2009 | 08:43 PM
JagtechOhio's Avatar
You need to have a scanner hooked up to your car to retrieve the fault codes now stored in your car's computer. Some auto parts stores have a scanner that will be sufficient to provide you with this information.
The most likely cause for this fault is a failed ignition coil, there are six on your engine. If that is the case, a code should be stored that will identify which cylinder has the bad coil. Send me a private message if you need one at a good price.
Otherwise, post the code numbers that are retrieved when the computer is scanned, and the picture will be a bit more clear.
Old Mar 18, 2009 | 09:37 PM
BHD2786's Avatar
you could hurt the catalyst if u drive it
BrentGardner
29
Dec 16, 2024 12:13 AM
jdzubas
Oct 4, 2015 09:14 AM
gene1
Sep 3, 2015 08:04 PM
gene1
Aug 27, 2015 09:35 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
