Engine swap
Old Feb 19, 2016 | 06:47 PM
Accidentaljag's Avatar
Default Engine swap
What issues do I need to look out for if I want to swap a Series 1 4.2l engine into the same model of car, but mine has a manual transmission and the oreplacement engine would be coming out of an auto?
Old Feb 20, 2016 | 08:31 AM
anjum's Avatar
Not AFAIK or hope. The issues are more with getting the correct matching drive-train for the manual setup, but you have those already. Maybe a few hose differences but again you have those on your car. I think the auto had an oil cooler for the transmission.
If you can hear the engine running and maybe perform a compression test on before buying it.
Old Feb 21, 2016 | 04:26 AM
None that I remember also.
You are keeping the manual, or going lazy with the Auto????
If its just the engine being used, easier.
I think?? the spigot hole in the crankshaft on the manual and the early BW transmissions is the same, but it has been a LONG while.
Old Feb 21, 2016 | 09:28 AM
slofut's Avatar
I'm pretty sure you'll have to use the autobox and send all the manual bits to me. Pm me for the correct address!
Old Feb 22, 2016 | 03:38 AM
Staying with the manual, definitely. The current engine has no compression in 2 cylinders, with a third dodgy. So rather than getting the engine rebuilt (which I can't really afford), and assuming I'll end up with parts left over if I strip and rebuild it, I thought an option would be to get a donor engine.
Thanks for the offer Slofut, if only I'd known earlier haha
timsalyer
Apr 6, 2016 01:02 PM
XJeej
Mar 18, 2016 06:06 AM
flyingfarmer
Mar 8, 2016 11:15 PM
smilemf
Feb 17, 2016 08:07 AM
harryc
Feb 13, 2016 03:36 PM
