Engine swap query
Old Oct 12, 2020 | 08:49 PM
brinny's Avatar
Default Engine swap query
Hi all, pretty new to these cars and don’t know much about the 4.2 engine yet so wondered if a 1986 series 3 4.2 engine would be a suitable transplant for a 1976 version? It has been converted to carburettors so would there be any other issues? Or is it a bad choice for any reason? Thanks for any help.
Old Oct 13, 2020 | 02:52 AM
o1xjr's Avatar
I have series 3 engine in my 73 series one, twin carbs fitted. No problem.
I have S3 electronic ignition as well.
Old Oct 13, 2020 | 04:10 AM
brinny's Avatar
Thanks. Think I would prefer electronic ignition too.
Old Oct 13, 2020 | 07:31 AM
Robert Laughton's Avatar
One small thing I ran into.....
The '76 will have a throttle cable/trans cable bracket bolted to the back of the right head, using the cam cover end plug bolts.
The S3 heads didn't use the half moon seals and end cap, so they stopped drilling and tapping the holes at the back of the head.
I got the engine all hooked up only to find no way to mount the throttle bracket.
If you drill and tap the head BEFORE you install the engine you will be fine.
Good luck,
Rob.
Old Oct 13, 2020 | 01:49 PM
brinny's Avatar
Good luck,
Rob.
Thanks that’s good advice and potentially saved me a lot of grief!!!
Old Oct 17, 2020 | 03:41 PM
littlelic69's Avatar
You may find that the crankshaft pulley/drive belt are mis-aligned and you will need to find the relevant offset components.
Peter Henauw
Oct 29, 2019 06:49 PM
stevee D
Jun 17, 2015 06:39 PM
Beauii60
General Tech Help
May 31, 2013 06:14 PM
fooche911
Apr 12, 2013 08:35 PM
wayne1991
May 20, 2009 12:39 PM
