Exit Compressor
Old Jun 16, 2015 | 04:12 PM
adenshillito's Avatar
Default Exit Compressor
no longer running a/c and compressor is entirely disconnected except for the belt that powers it, can i assume that as the belt is merely piggie backed to another and not essential to any other device that I can removed both the compressor unit and the belt that drives it without any problem being cause any where else?
Old Jun 16, 2015 | 08:13 PM
Stoney85's Avatar
The main belt you require on an engine is the one that operates the alternator and water pump, that belt is on its on pulley
The A/C unit uses its own V belt and tensioner pulley, removing that belt will not be a drama.
The same with the Air pump.
If you completely remove the A/C compressor, running a new fuel line ($5) will be required to bypass the cooler that's in the A/C unit.
A lot of weight in the A/C system.
Old Jun 17, 2015 | 06:17 AM
Jose's Avatar
one of the belts also turns the power steering pump.
just remove the compressor belt, but not the compressor.
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
04Xjrsteve
May 7, 2019 04:06 PM
dmatthewman
Sep 30, 2015 10:10 AM
dan102877
Sep 29, 2015 06:47 PM
