Firewall battery terminals
Old Nov 26, 2015 | 02:55 AM
yarpos's Avatar
Default Firewall battery terminals
As the cars came out of the factory , were there any protective boots over these posts?
I really dont like those things exposed and will be protecting mine, but I am interested if bare = normal. I have checked one other car and found them bare, but dont know if that means the covers rot away or they are never there.
Old Nov 26, 2015 | 03:06 AM
Jag-o-nomic's Avatar
Hi Steve,
All Series 3's had push on type terminals with braided leads and rubberised covers for each terminal.
These were colour specific to signify polarity. Red - Pos, Black - Neg
Most have perished and weren't replaced, so aren't there today.
Cheers,
Nigel
Old Nov 26, 2015 | 04:14 AM
Yep.
They had a rubber cover on each side.
The fact they were British Non-metallic components, rotted within about 5 years. They sort of "hung on" for another 5, if left undisturbed, but after that, gone.
I tried to buy some when I had the Series cars, but got too hard. I knew they were "bare" and never got caught out.
Old Nov 26, 2015 | 04:50 AM
Hi Grant,
As a follow up.
Depending on what battery you fit, clearance with the bonnet is / should not be an issue.
I always liberally smear high temp bearing grease on my terminals, primarily to ward off oxidation and resultant terminal fluff.
Never had an issue.
Cheers,
Nigel
Old Nov 26, 2015 | 06:25 AM
Agreed, many a scorched S2 bonnet from that little blunder.
My understanding was thread was in regard to the battery cable +ve threaded posts on the firewall, one each side, that came with rubber 90deg elbows as a covering???
Old Nov 26, 2015 | 06:43 AM
icsamerica's Avatar
I think yarpos is referring to the threaded fine 3/8 posts that penetrate the firewall. The inside or interior has a rubber boot. I have never seen a cover on the engine compartment side.
As for the aformentioned top battery terminal issue...new leads and a side terminal battery is a practical retrofit.
Old Nov 26, 2015 | 06:46 AM
S.Bunzel's Avatar
Found it. I knew that I had seen it some place :-)
Old Nov 26, 2015 | 08:34 AM
JagCad's Avatar
An all of the above answer???
My 83 has a side post battery. good, but with reservations. when, I was having starter travails, the negative connection in the battery case just melted!!! High draw of done for starter??? A little tin cup with formed threads was imbedded in the lead.Lead melted. No connection anymore. Battery replaced with a spare. All is well now. That would never happen with the husky lead posts found on top post batteries.
Yes, there was a remnant of a rubber like cap on the fire wall post. Lost in the lumping shuffle. I don't recall a similar thing on the starter solenoid.
Sans covers seems to function just fine.
Carl
Old Nov 26, 2015 | 03:24 PM
jagent's Avatar
Yes he is. We had a conversation about it and I expressed similar concern since discovering mine are the same. I'm going to find some kind of cover, don't like them exposed.
Old Nov 26, 2015 | 09:23 PM
yarpos's Avatar
Thanks all for the responses. I think I will just buy a variety of protective boots from Ebay and see what fits the best. I went through the same process with the little Morris I am slowly resuscitating.
Old Nov 26, 2015 | 11:29 PM
Default Love a tangent
Hi Steve,
Sorry to go off at a tangent.
I'll read the question a second time before answering next time.
I just remembered that my English teacher used to regularly repeat that to me 30 years ago at school.
My spots must be a bit rusted on!
In regards to the boots that you were enquiring about, a couple of the well known jag specialists seem to stock them when I just checked on them.
Item C30693
A couple of pounds each plus postage.
Cheers,
Nigel
Old Nov 27, 2015 | 03:27 PM
jagent's Avatar
Steve, I've been wondering if those small rubber chair leg cups could be tweaked to fit. Bunnings have them in different sizes from tiny to quite large - it's a long shot, but a cheap fix if it works. I'll investigate.
Old Nov 28, 2015 | 06:26 PM
jagent's Avatar
Before heading off to Bunnings I decided to delve into the black hole (aka bits box) and voila! found 2 rubber cups. No idea where they came from, no doubt of some ancient origin. Probably used for a similar electrical purpose I'm guessing...Anyhow, they're a perfect snug fit over the expose nuts. I might pull them off again and add a bit of silicone for a little extra seal.
Not a perfect solution as the back end of each terminal is still exposed, but it's a start.
Attached Thumbnails Firewall battery terminals-20151129_102456%5B1%5D.jpg   Firewall battery terminals-20151129_102516%5B1%5D.jpg   Firewall battery terminals-20151129_102624%5B1%5D.jpg
Old Nov 28, 2015 | 11:00 PM
yarpos's Avatar
Certainly stop an inadvertent slip of the spanner hitting one. I have some covers coming from Ebay that fit over the cable , then the terminal (if I got the sizing near the mark). Will post if they are any good, and will have some to share as minimum order = 10.
Old Nov 29, 2015 | 12:06 AM
jagent's Avatar
No worries Steve, happy to buy some from you if good. I was thinking a bigger cup would be better - maybe cut a slot to slip over the cables.
Old Nov 30, 2015 | 12:05 PM
Jose's Avatar
the 1982 thru 1984 batteries were side mounts, and they had plastic or "nylon" snap covers over each terminal. The nylon covers were part of each cable; my 1984 still has them, I will take a picture and post it later.
Old Nov 30, 2015 | 01:47 PM
JagCad's Avatar
Jose:
My 83 as well. But, on the cable end that goes on to the battery. Other ends
now bare....
Carl
Old Dec 2, 2015 | 08:18 AM
Jose's Avatar
Carl, here's the cables and caps in my 1984:
Attached Thumbnails Firewall battery terminals-01-xj6-battery-terminals-vinyl-covers.jpg   Firewall battery terminals-02-xj6-battery-terminals-vinyl-covers.jpg   Firewall battery terminals-03-xj6-battery-terminals-vinyl-covers.jpg   Firewall battery terminals-04-xj6-battery-terminals-vinyl-covers.jpg
Old Dec 16, 2015 | 06:51 PM
yarpos's Avatar
Me Ebay envelope arrived so I thought I would see if my guesstimate sizing worked and I could add some protection to these terminals.
Passenger side near battery before:
After (couldnt quite get that wire in with the battery cable, but still its a ot more protected.
Drivers side before:
Drivers side after (more complete cover on this one and also gave me the opportunity to tidy up a spaghetti junction)
Bit more protected from an inadvertent strike and the red is a bit of a flag about whats lurking there.
Old Dec 16, 2015 | 07:02 PM
jagent's Avatar
Nice one Steve, glad it worked. I like that they're red.
