fuel filter for 86 XJ6
Old Jul 30, 2013 | 11:50 AM
gray cat's Avatar
Default fuel filter for 86 XJ6
I think it's time to change the fuel filter. what's a good brand and is it a fairly easy install ???
Old Jul 30, 2013 | 01:07 PM
icsamerica's Avatar
Default very easy
Your filter should be in the spare tire well in the US passenger side forward corner. The easy factor depends on how much junk is in your trunk. Once there...its a simple matter of undoing the clamps and replacing the filter. Make sure you have some rags and a fire extinguisher at hand and use a safe lamp such as a battery powered LED flashlight. NEVER use a incandescent or unsealed florescent lamp anywhere near fuel.
Just about any brand will do. Wix is good and usually available at your local NAPA. Get two and keep one in the spare tire well as a spare incase you clog up on the road, at night. Get some new Fuel injection style high pressure clams while your at the auto parts store just in case. Get the good ones over the counter, not the junk in the HELP packages.
Old Jul 30, 2013 | 01:25 PM
gray cat's Avatar
hey that's great news !! easy install, would a Bosch filter work well ??
they are about $30 less than some of the other brands
Old Jul 30, 2013 | 06:41 PM
Doug's Avatar
Bosch, Wix, AC Delco....all fine for your Jag. Any of the name brands should be OK.
Old Aug 2, 2013 | 02:06 PM
gray cat's Avatar
Smile
Good thing I changed the fuel filter , the old one was very clogged and now she runs quite a bit better !!! plus it was easy access in the trunk and easy to change
aholbro1
Dec 29, 2024 06:46 PM
Sprayall
May 30, 2021 08:13 AM
rusty37
Apr 5, 2020 07:40 PM
1100me
Sep 7, 2015 06:26 AM
Sprayall
Sep 3, 2015 07:49 PM
