Fuel smell
Old Apr 18, 2024 | 07:06 AM
WillieK's Avatar
Default Fuel smell
My ‘86 xj6 emits a terrible fuel oder in the trunk after running. All trunk hoses good and connections tight. No seepage. Thoughts please? Thanks!
Old Apr 18, 2024 | 07:39 AM
Doug's Avatar
The tanks might be leaking and the odor migrating into the trunk.
The fuel pump and/or fuel solenoid might be leaking
Did you check the hoses for the vapor and vent systems? The ones by the trunk lid hinges?
Bear in mind that in this scenario (small, closed compartment) even the tiniest leak....virtually invisible...will cause a problem. Wrap all joints and components in colored tissue paper for a few days. Escaping fuel vapor will discolor the paper.
Sometimes the fuel vapors seep right thru the hoses. Changing to marine grade fuel hose worked well for me. It's more vapor-proof than the automotive grade low permeation hose in my experience.
Old Apr 19, 2024 | 06:29 AM
WillieK's Avatar
Default Fuel smell
Doug, thank you for your helpful response!
I will recheck per your recommendations.
Old Apr 19, 2024 | 10:34 AM
Malcolm Ridgway's Avatar
Default Fuel smell
[likely leaking tank(s). Take off plastic bung underneath where the drain plug is and smell there. QUOTE=WillieK;2741758]My ‘86 xj6 emits a terrible fuel oder in the trunk after running. All trunk hoses good and connections tight. No seepage. Thoughts please? Thanks![/QUOTE]
Old Apr 22, 2024 | 05:24 AM
Well-Travelled's Avatar
Totally agree with other comments here; having experienced exactly the same issue. This is almost certainly a pump, tank or line issue. Unfortunately, it is often the tank being the root cause. Less so pumps. But degraded lines for the older unused cars is something to watch for.
These XJ’s are notorious for rusting out. Mine spent 40 years in Australian heat and still rusted out. So you need to keep drain pipes (near filler neck) clear and tanks generally full to avoid the dreaded issue of moisture getting into the tanks and rusting them out.
Resolved mine with new tanks, new pumps and new lines. Better safe than sorry!! There should be no smell of fuel in the trunk, at any time. Not just after driving.
Good luck with your investigations.
Old May 4, 2024 | 08:40 AM
XJDanny's Avatar
My ‘87 has a fuel smell in the trunk, too. Isn’t that a common issue with these cars, and doesn’t necessarily imply a fuel leak? I’ve just been ignoring mine because the trunk has always smelled and I have replaced the fuel lines and pump. The smell does not enter the cabin. I only smell it when I open the trunk.
Old May 4, 2024 | 11:54 AM
Doug's Avatar
Yup. A leak, for sure.
But it might be just the tiniest weeping. It doesn't have to be a wet leak to cause a huge odor.
Old May 4, 2024 | 03:56 PM
garethashenden's Avatar
I would say that it is both a common problem and implies a leak. If you can smell fuel without opening up the fuel system, there's a leak somewhere.
Patrick 1989 XJS
May 14, 2024 05:34 AM
benji808
Oct 30, 2023 05:01 AM
Quadcammer
Apr 25, 2023 08:06 AM
Norfolk Enchants
May 6, 2022 08:53 AM
Jairo Rivera
XJ40 ( XJ81 )
Feb 26, 2020 08:45 PM
