Fuel tank cleanliness (pic)
Old Aug 7, 2025 | 03:18 PM
bullittandy's Avatar
Default Fuel tank cleanliness (pic)
I recently had the need to drain my fuel tanks to make some changes to fuel pump set up on my 6 liter swap in my ‘74 XJ12.
I put new tanks in three years ago and have probably 1000 miles in the car in total driving with those tanks. And I was surprised how much sh*t was in them. I mean, it wasn’t visible while draining but still, I can see the benefits of draining the tanks now and again. I should note I cleaned and flushed the fuel lines and tanks before install so that’s stuff I couldn’t get out or stuff that got in over the past 3 years.
Old Aug 7, 2025 | 07:30 PM
Doug's Avatar
This is why lots of Series III owners add two filters (left and right) between the tanks and the pump.
I'm not familiar with Ser II fuel plumbing so I can't say if such a thing would be feasible. Might be worth thinking about.
Old Aug 8, 2025 | 04:18 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
Doug's comment about dual filters is very wise, FYI here is a picture of mine in an S3. In addition, the stock filter is still in place down stream from the pump.
Dave
Old Aug 8, 2025 | 10:57 AM
slofut's Avatar
Probably stuff pumped in there from the gas pumps and stuff you couldn't get out, true. I cleaned mine the same, new tanks and rubber lines, cleaned carb flushed and blew out hard lines etc... Have a glass filter at the carb and have still dumped it out several times! Amazing. This wouldn't do for fuel injection components.
worzella
Jan 18, 2025 06:19 AM
944xjs
Apr 9, 2022 10:18 AM
Darrenmb
Feb 5, 2021 07:34 PM
Woznaldo
Jun 4, 2013 05:48 AM
calvindoesntknow
Aug 28, 2012 03:34 PM
