Gauges in Instrument Panel Stopped Working
Old Jan 31, 2019 | 07:13 AM
Jose's Avatar
test it with a jumper wire or a paper clip.
if the gauges come alive, just solder a jumper on both broken pieces.
Old Jan 31, 2019 | 07:24 AM
iramphal's Avatar
Looks as if that has shorted out and burnt. The lacquer insulation is not there anymore. Did you remove it or has it shorted out by itself?
Tracing that broken line, it appears to head back to pin 7 on that 7 pin black plug. You said you had 12 V on that #7 pin. Check if you get the same 12V before the break. You should get !2V. Then check on the other side of the break and if you do not, then I would solder a jumper wire across the break and re-insulate with silicone RTV or good electrical tape.
As per your diagram, pin 7 supplies voltage to those gauges. I assume item 64 is the gauge voltage regulator that takes it down to 10V.
Old Jan 31, 2019 | 10:00 AM
Yellow series3's Avatar
This is where you use your ice pick test light. If it needs soldering I suggest taking it to someone with lots of experience soldering cuircit boards, etc. Like a computer repair place with an old timer. I fortunately have a friend that used to build those Tandy kits back in the 50s and 60s and is really good at soldering. I have never mastered that skill and actually caught things on fire trying.
Also, if you havent already, contact David at everydayxj.com to see if he has a used one. His prices can't be beat and if something doesn't work he bends over backwards to make it right.
Jeff
Old Jan 31, 2019 | 02:08 PM
pbuhler13's Avatar
So I was able to get jumper wires on the way home from lunch and jumped the broken ribbon cable in the instrument panel and boom were in business.
I got a buddy who does some electrical work, hopefully he can make it permanent! Thanks all for the help!
Old Feb 1, 2019 | 06:54 AM
iramphal's Avatar
Bingo! You're welcome.
Old Feb 1, 2019 | 07:40 AM
cds's Avatar
cds
Default Late to the party, but the same thing happened to me
https://forums.jag-lovers.com/t/some...s-smoke/364921
It’s a pretty easy fix you need a soldering iron with a fine tip.
danwebman
XJ40 ( XJ81 )
31
Jan 21, 2015 04:32 PM
jonscot
Apr 21, 2014 11:03 AM
marvin1960
Aug 6, 2013 07:03 AM
mattjagger
Mar 15, 2012 05:16 PM
