Great DIY video on windscreen removal and install
Old Oct 14, 2020 | 01:36 PM
Yellow series3's Avatar
Default Great DIY video on windscreen removal and install
I had read about the seal on the windscreen. Here is a great video from the "Living with a Classic" YouTube channel. He does it by himself with a little bit of help from his wife for fitting the glass back in. Definitely do-able. Here is the
Old Oct 14, 2020 | 09:09 PM
Jahmiata's Avatar
I love his channel! Keeps me motivated to work on my S1. I you haven't please become a Patron and support his channel. His "prices" are cheap.
Jeff H
Old Oct 15, 2020 | 06:52 PM
Larry Louton's Avatar
Does this video also apply to a Series 3?
Thank you.
Larry Louton
Old Oct 16, 2020 | 03:14 PM
prettydaim's Avatar
Default refitting the stainless windscreen surround DYI video
Hi All, Does anyone have a link to to see the re fitting of the windscreen surround , the DYI video was a great incentive to do this job as it has always thought to be a frightening task but re fitting the stainless without damage is a worry a video to conclude would help.
Old Oct 16, 2020 | 04:07 PM
I agree. The removal video was posted this week and he said if we want to see the trim installed to leave a comment (below the video).
Old Oct 16, 2020 | 06:02 PM
prettydaim's Avatar
Thanks Ys3, Much obliged I did not notice it, PD.
Old Oct 16, 2020 | 06:14 PM
prettydaim's Avatar
I have looked below the video but cannot find where to comment ,must be getting old, PD
Old Oct 17, 2020 | 07:38 AM
metalbasher's Avatar
Larry, the SIII is bonded in with a sealer rather than a gasket. It's still not difficult to perform. My daughter helped me do my front windscreen - at the end of the installation I had mastic all over me and she didn't have a speck on her...
Old Oct 17, 2020 | 07:59 AM
Metalbasher, disappointed to learn that the video doesn't apply to series IIIs. Any chance you and your daughter can make a YouTube video to show us how it is done?
Old Oct 17, 2020 | 12:09 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
I just finished reinstalling my front windshield and agree with everything you said Ken. The process is not hard, but the adhesive is miraculous. If you get within 6" of it, it will jump onto your fingers (or so it seems). Acetone will clean the adhesive from any surface, but it will also take a layer or two off your paint job. Mask very closely around the body opening. My down-fall as a first timer at this was knowing how much adhesive to put in the channel. I felt that too little would leave voids which would recreate the rust problem, and too much (as I chose) created a mess when inserting the chrome and trim pieces. My back glass should go more smoothly, I hope.
Dave
Old Oct 18, 2020 | 05:11 PM
I don't know about a DIY video from me on that due to the likelihood of a fair amount of sulphurous language ending up on it. I also went the Alyn Murray route and used black silicone in lieu of the plastic inserts around the chrome.
Need to get paint on Blue Six before I tackle the rear windscreen (which is not leaking right now).
Old Oct 21, 2020 | 10:34 AM
Originally Posted by metalbasher
...before I tackle the rear windscreen (which is not leaking right now).
I am a Firm believer in, "If it ain't broke, DON'T MESS WITH IT!"
Old Oct 21, 2020 | 02:50 PM
prettydaim's Avatar
Thank You All for your replies, In the future when I may need to remove front and rear screens I would like to have the knowledge as I have heard stories of disaster refitting the stainless trims, also now I am not sure if that video refers to series 111 models and speaking of S111 does the front screen have a similar seal to the rear, PD.
Old Oct 21, 2020 | 09:12 PM
LT1 jaguar's Avatar
The pinch-weld seal on the front windshield is different from the rear glass. The inner and outer finishers that go on either side of the stainless trim is the same front and rear.
Dave
Old Oct 22, 2020 | 03:59 AM
prettydaim's Avatar
Thanks Dave Much Obliged, John.
jagstuart
Mark V - X 420G
Feb 25, 2020 08:40 AM
anyoldiron
Oct 4, 2019 01:10 AM
MediaBobNY
Apr 19, 2017 04:07 AM
Ubad2
Nov 3, 2016 09:03 PM
JimC64
Jun 7, 2016 10:39 AM
