Happy now
Old Oct 26, 2014 | 03:16 AM
Mad Matt's Avatar
Default Happy now
Sorry been a while guys, not divorced yet. Lady J is performing well. Changed the exhaust today. Now sound like a jag and not a f150 deisel. Now just have fix some minor issues. Return line to left hand tank not working. Heater not working, and finally i have noticed that the aircon stays on windscreen all the time. But all in good time. Thanks guys to those have helped with ideas.
Old Oct 26, 2014 | 05:53 AM
o1xjr's Avatar
Sorry Matt, no answers for you with your issues. But good see you back on the forums.
Old Oct 26, 2014 | 11:06 AM
Doug's Avatar
If that's the only aspect of the changeover system that isn't working properly then I suspect you simply have a dead return valve. This is the valve mounted behind the left rear wheel.
Heater not working,
Does the heater valve operate? Look at the valve....it has an external operating arm....while a helper operates the temp control knob from cold to hot
Lots of possibilities. All all four system fuses OK?
When you switch modes or temp settings do you hear a faint whir from behind the dash?
jluckcuck
Nov 6, 2015 07:49 AM
RedRider48
Oct 1, 2015 08:18 AM
Msteiner
Oct 1, 2015 01:18 AM
mrplow58
Sep 30, 2015 08:56 AM
sdelliott58
Sep 28, 2015 11:21 PM
