HE Vacuum Advance on Pre HE Distributor
Hi all,
Long time no speak.
Hope everyone is well and you're looking after yourselves.
Quick question - I hope...
Can a Pre HE V12 D-Jetronic distributor be fitted with a vacuum advance module from an HE V12?
Thanks in advance,
Roger
Long time no speak.
Thanks in advance,
Roger
Yes Roger.
Then run the vac hose from the engine side disc spigot under the A bank throttle body.
If that is not there use the spare spigot on the A Bank Inlet Manifold end plate at the rear.
You will need to "Drive Time" it after that, as the timing marks will mean little as far as purist stuff goes. I started with 10deg ish BTDC, and then upped it until the engine was just "on song". I seriously doubt you will get a PreHE to "ping" like the HE, none of mine ever did, and I have no idea where the timing ended up, they just ran SWEET.
Your PreHE would have a 15deg mechanical advance (HE Aust is 13 Deg).
V12_daimler88
Apr 19, 2020 01:53 PM
