Heating and Ventilation vacuum diagram
Old Mar 25, 2018 | 03:22 AM
John Keith's Avatar
Default Heating and Ventilation vacuum diagram
Good morning, hope someone can point me in the direction of a line diagram for my XJ6C heater vacuum piping. The tubing connectors have perished and dropped off. I have replaced a most and tested the main flaps etc with a small vacuum pump but when operating I am still losing vac somewhere.
A diagram will help, I'm sure, or, I just muddle along testing until I find the problem. Just so awkward to get to everything!
Thank you
John
Old Mar 25, 2018 | 08:33 AM
alynmurray's Avatar
Here is what I have,.. may be what you are looking for.
Attached Thumbnails Heating and Ventilation vacuum diagram-jaguar-climate-control-vacuum.png   Heating and Ventilation vacuum diagram-jag-vac-3.jpg
Old Mar 25, 2018 | 09:21 AM
JagCad's Avatar
Alyn:
Thanks from here as well. As clear a diagram that I've ever seen. I saved it for adding to my Jag lore.
It's been on the cold side around here. 50's F. I was going to use my Jeep for errands as I fancied it's strong warm air production.
But, the Jaguar beckoned. It must've been challenged!! It fired right up and purred/ After just a bit I set the temp on 85 and the fans to Defrost. I was greeted with a pleasant flow of warmth. Actually 1/2 way to the first stop, I backed the temp way down. The cat asserted itself.
Carl
itchyback
May 14, 2017 08:54 AM
new mexico
Apr 29, 2017 02:28 PM
Paulo Santos
Oct 14, 2016 08:21 AM
Karlsund
XJ40 ( XJ81 )
May 18, 2013 12:42 PM
ian1975
May 8, 2012 08:53 AM
