help on 1984 xj6 horn problem
Old Oct 26, 2009 | 06:56 PM
m0t0rm0uth's Avatar
Hey XJ.
1. Your horns are located behind the front bumper.
2. The problem could be your horn button itself, the horns, a short in the electric lines, etc.
3. See #2.
Old Oct 27, 2009 | 08:01 AM
Doug's Avatar
This might help:
http://www.jag-lovers.org/xjlovers/xjfaq/horn.htm
Old Aug 5, 2010 | 10:38 AM
Kalahari's Avatar
DD - Thanks for the link to the horn troubleshooting. It was very helpful. Again the Multimeter is proving a very valuable diagnostic tool.
Looks like the horns are getting power when the button is pressed and since they do nothing with supplied directly from the battery it looks like time for new horns.
FYI - The 130 db freeway blaster horns at Advance Auto Parts seem to be the same part I'm finding on the Napa website. Picking up a set @ lunch.
Old Aug 5, 2010 | 03:00 PM
Fraser Mitchell's Avatar
Unusual for both horns to fail, even one, as they are used so little, (unless maybe you are from the Mediterranean countries !!). You could also make sure the ground (UK=earth) connection is OK.
Old Aug 5, 2010 | 11:17 PM
Kalahari's Avatar
Rain tonight so I didn't get them installed. I checked the wiring with my multimeter. Both were receiving 12v when the horn button was pressed. The ground was touching the bolt the ground wire was connected to. I'm with you on both failing, but both were dead when connected directly to the battery.
Old Aug 5, 2010 | 11:43 PM
Doug's Avatar
I disagree with the rarity of both horns failing. I've seen it a few times. The location under the bumper leaves them totally exposed to the elements.
An ambitious person (not me) would move them to some place with a little weather protection
Old Aug 8, 2010 | 08:21 AM
Kalahari's Avatar
We have horn! The 130 db horns from AutoZone did just fine.
Old Oct 17, 2011 | 08:45 PM
tsingtao35's Avatar
my horn works when pressed on the right side of the horn pad on the steering wheel, problem is it sounds like the road runner..left side has no sound. any answers?
Old Oct 17, 2011 | 08:56 PM
Doug's Avatar
Remove the horn pad (two screws from behind) to adjust the metal contact plate.
As for the sound, well, your low-note horn is probably dead. Universal fit horns from any auto parts store are easy to install and work fine...$12-$15 each or so
jdzubas
Oct 4, 2015 09:14 AM
laserguy
Sep 3, 2015 02:02 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
pnwrs2000
Sep 3, 2015 11:55 AM
