My 76 xj12 keeps blowing fuse #3. This is a 35amp fuse that powers most of the interior accessories. What could be wrong? Where to start?
Doug
close
- Join DateMar 2008
- LocationPacific Northwest USA
Liked:11,721 Times in 7,586 Posts
Does a new fuse blow *instantly* ?
Is there one particular accessory that always blows the fuse? Or combination of accessories?
Do you have a wiring diagram?
One method is to determine exactly what's on that fuse and systematically start disconnecting sub-circuits until the fuse no long blows
Yes, the fuse blows instantly and yes I have a wiring diagram but to me it's useless as I am an electrical moron. Your suggestion on sub circuits make a lot of sense, that is where I will start.
Doug
close
- Join DateMar 2008
Quote:
That's an easy place to start. Unplug the lighter wires.Originally Posted by Paulie63
Nothing in the cigar socket, but it is crusty in there.
In that case it has to be an item that is permanently powered.
Possibles are: Ignition Switch, Interior Lights, Clock, Door Locking, Hazard Switch, Light Switch, Footbrake light switch., Radio.
I do not have a diagram for your vehicle but if you can see the fuse on the diagram then follow the lines to the items that it powers.
Roger
Roger
The Haynes should be Ok. I have the 86 XJ6 one so I admit it is pretty cluttered as everything is on one page. But you will need to persevere with it.
Roger
Roger
