help! Vacuum capsule advise needed V12
Old Jun 3, 2018 | 10:52 PM
Alan Lindsay's Avatar
Default help! Vacuum capsule advise needed V12
Hi all,
Help! I need advise regarding the the vacuum control capsule on my Australian fuel injected 1978 Series 2 Daimler Double Six.
The unit has failed and I noticed a replacement on eBay offered by my usually helpful Melbourne parts supplier.
Apparently the failed item is an advance/ retard capsule with pipes attaching to both sides of the diaphragm ie 2 outlets. The one for sale is a straight vacuum advance with only manifold suction outlet.
At this stage the parts supplier was less than helpful with some talk of timing changes etc.
I am very keen to know if this unit can be adapted to my car and if so what changes are required.
Any information greatly appreciated
Al
Old Jun 4, 2018 | 03:53 AM
Should be plug and play, basically.
Ours had the twin thingy, replaced with the advance only.
Vac supply via a hose to the spare spigot on the rear of the RH inlet manifold. Would have preferred a signal from a throttle body underside, but ours had no spigots there.
Set the timing static 10deg BTDC, and then fined it up by "drive timing" it, as I do all the V12's.
v1rok
Sep 17, 2017 12:41 PM
heflirob
Oct 21, 2015 06:39 PM
gmcgann
39
Feb 2, 2015 09:42 AM
stypemadd
Feb 1, 2014 07:34 PM
