Horn Button Stick On
I am having difficulty getting the screws off the back side of my steering wheel, to get at the sticking horn buttons. Is it easy to remove the steering wheel so I can get to the screws on the backside.
Have you got the steering wheel out to its maximum extent ? I used to use one of those stubby short screw drivers about 3" max in length, but the wheel has to be moved right out to max position first.
He means to turn the big black knurled piece below the wheel - CCW to loosen it... then pull up the wheel to the maximum height to gain room underneath. Good luck if it has not been loosened for years!
Thank you for the advice. As it was difficult to see whether i was having success loosening the two backside screws, I was able to remove the steering wheel, and complete the task, in a different manner.
Thanks for the advice. I appreciate it
Jim
Jim
JimC64
Sep 22, 2025 02:52 PM
FS[MidWest]: Parting Out 1997 XK8 Red Conv II
CyJag
38
Apr 23, 2017 10:58 PM
abonano
Oct 3, 2016 10:09 AM
