How to remove a fuel tank for a XJ6 S2 1978
Old Dec 31, 2020 | 11:34 AM
metalbasher's Avatar
Bought both of my tanks from Rockauto. It was the cheapest place I found; they were made in Canada by Spectra Premium.
Around 275 bucks if memory serves...
Old Dec 31, 2020 | 07:55 PM
Karl S.'s Avatar
Banned
Well called Rockauto they dont have any in stock and neither did jc whitley however jc Whitley had some good bundles for me to make things cheaper on me and we are going to split the shipping cost lol so she says lol
Old May 25, 2021 | 05:32 PM
4catstudio's Avatar
Well, I’ve been through all of the above, one way or the other..
I was expecting the tank to just slide or fall out.
‘No luck. Any suggestions?
Old May 30, 2021 | 05:16 PM
lickahotskillet's Avatar
My right tank was creased in with hidden body damage. The crease in the wing, made a crease in the tank. I had to adapt a slide hammer to the drain bug. Then I pounded it out with the slide hammer. Left tank pretty much was wiggled out. New series 3 tanks pretty much slid right in.
Old May 30, 2021 | 06:47 PM
4catstudio's Avatar
I eventually worked it out. The vent tube was making it stick; spraying it with lithium grease, and a firm yank on the bottom edge of the fender line, along with some persuasion with a wood block and rubber mallet on the filler neck succeeded.
I have posted this elsewhere, but I’m looking for a good used submerged fuel pump mounting assembly. A previous owner had welded it up around the outlet tubes and that repair has gone south. Replacements are only available as a unit with a pump; the car was changed to an external pump previously.
Reverend Sam
Apr 8, 2023 02:42 PM
AccidentlyInLove
Mar 22, 2017 12:46 AM
kev53
Jan 26, 2015 07:28 AM
ximineszimo
Dec 28, 2013 10:38 AM
Filip
Dec 13, 2009 12:51 PM
