I keep loosing the same cylinder. V12.
Old Jul 10, 2018 | 04:07 PM
Flappers's Avatar
Default I keep loosing the same cylinder. V12.
1989 Daimler Double Six 105.000 miles.
Hi folks. I've had this recurring problem for a few years now. I've have the garage replace the plugs, clean the electric connector to the injectors. Doing that gave me about 4 months of trouble free motoring. It happened again last month and I tried a different plug, not the "S" and it's dropped the a cylinder on the same bank yet again within a couple of weeks She doesn't get huge runs out sadly, I mostly do local stuff. I'm having a different mechanic look at it next week. I did put racing leads on it a few years ago, is it worth me buying more high end leads or shall I just buy the standard lucas ones please ? Why would it keep loosing the same cylinder, does it just need tuning ? I had them do a compression test and all cylinders were in working range.
Old Jul 10, 2018 | 04:16 PM
new mexico's Avatar
Hi folks. I've had this recurring problem for a few years now. I've have the garage replace the plugs, clean the electric connector to the injectors. Doing that gave me about 4 months of trouble free motoring. It happened again last month and I tried a different plug, not the "S" and it's dropped the a cylinder on the same bank yet again within a couple of weeks She doesn't get huge runs out sadly, I mostly do local stuff. I'm having a different mechanic look at it next week. I did put racing leads on it a few years ago, is it worth me buying more high end leads or shall I just buy the standard lucas ones please ? Does it just need tuning ?
I would replace all spark plug wires.
Replace the distributer cap.
Walter
Old Jul 10, 2018 | 08:26 PM
Doug's Avatar
Does the spark plug look black, oily and gunky (high tech terminolgy there!) each time? Or perhaps black and sooty/fluffy?
The former would suggest an oiling problem, perhaps a valve seal issue. The latter would suggest over-fueling.
Old Jul 11, 2018 | 09:04 AM
JagCad's Avatar
Flappers:
1. What are "racing leads" ? In olden days, a metallic core. Made the use of a radio impossible. Or just a label ? Better quality or a means of charging a higher price!!
2. Yes, Doug is on the once very prevalent reading of spark plugs for engine condition. Modern fuels make this not quite as informative, but still very informative.
3. Brings back memories of A school chum's car. given him as hand me down family car. A 31 ****** sedan. This was circa 1948. It looked decent and ran well, for a while. It's well worn six cylinder flat head ate oil. So, during an evening out, it would drop a cylinder or two. We took a wrench along and could track down which cylinder fell asleep. Remove the plug and sure enough a blob of oily carbon in the electrode. Our fix was simple. A length of wire,, a bit of rag on the end. Dip it in the tank. Light it up. Hold it to the spark plug. Carbon blob burned away. replace and continue the evening. looking for willing gals. Stop light racing, ditch 'em, etc...
Carl .
Old Jul 11, 2018 | 12:55 PM
Flappers's Avatar
Originally Posted by JagCad
Flappers:
I just remember talking to a seller via ebay and buying what feel like better quality leads. I'm buying lucas leads with the dizzy cap.and having the new guy give everything a good clean The plugs were wet with fuel last time they were removed and I've recently left a car behind me in a fog of black smoke. What can be done to "tune" the engine please. Forgive me I know some but very little compared to the knowledge here. Thanks for your help.
Old Jul 11, 2018 | 08:38 PM
Doug's Avatar
Some of the common causes of over-fueling are....
- ruptured fuel pressure regulator
- fuel pressure regulator allowing excessive fuel pressure
- faulty coolant temp sensor
- faulty injector harness, causing injector(s) to stay 'on'
- broke/disconnected vacuum hose to the ECU (computer) in the boot
- leaking fuel injector(s)
More detail on any of these items on request
Old Jul 12, 2018 | 10:25 AM
JagCad's Avatar
And another for which I am very embarrased (sp) !!!!
Dirty air cleaner !!!
Carl
Johnken
May 17, 2017 09:09 AM
Bigvettefreak
Oct 24, 2015 08:47 PM
foxylady
Dec 28, 2014 02:52 PM
XJ40 ( XJ81 )
Dec 10, 2006 09:05 PM
