Ididit telescoping and tilt steering column
Old Jun 10, 2019 | 05:19 PM
Roger Mabry's Avatar
Default Ididit telescoping and tilt steering column
Am considering installing a custom Ididit column but would prefer to maintain the stock Jaguar ignition switch (just for looks). Has anyone done this and if so, how did you mount the switch without it being attached to the column?
Alternative is the GM switch in upper column but then would have to make up custom dash fill in pieces for the missing ignition switch.
Old Jun 19, 2019 | 09:14 PM
Cabel's Avatar
Use the key in the column just to turn on 12v and unlock the column, then put a big modern "Start" button where the stock switch went.
Col_T
Feb 19, 2019 07:13 PM
Greencar89
Jul 11, 2016 06:31 AM
ragman1171
Aug 23, 2014 05:38 AM
Linda's Jag
Jan 16, 2011 12:27 AM
poor boy
May 30, 2010 09:25 AM
