Ignition info needed
Old Nov 12, 2022 | 08:47 AM
denis4x4's Avatar
Default Ignition info needed
Trying to figure out if the problem is in the key or the wiring. Starter motor continues to spin when the car starts. Looking at the catalogs, there is a wiring kit for a Series lll, no mention of the Series ll. Actual key is on/off is unavailable. Help!
Old Nov 12, 2022 | 10:57 AM
Scd's Avatar
Scd
The starter is still receiving a signal to engage. Most likely is the ignition key mechanism is sticking or faulty and not returning to the ignition on position when you release the key. Less likely is a faulty starter motor relay. The ignition wiring is the same series 2 and 3 ( well at least in the UK) . If you are confident with following the Jaguar wiring diagram, disconnect the ignition multi connector under the lower panel and bypass the key by bridging the wiring, this will show you whether the problem is key or relay related.
Old Nov 12, 2022 | 11:34 AM
JagCad's Avatar
Check out the diodes.
Been there. done that
Doug Dooren
Jan 9, 2022 08:55 PM
ruffindustries
Jan 1, 2022 02:57 PM
alsemus1
E type ( XK-E )
Dec 17, 2019 10:56 AM
mikega
Aug 24, 2018 06:06 PM
whattrouble
E type ( XK-E )
May 23, 2013 09:31 AM
