ignition switch 1972 xj6
Old Dec 18, 2018 | 12:37 PM
stroud09's Avatar
Default ignition switch 1972 xj6
The ignition switch won't turn the engine off? 305 chev conversion. Have to ground out the ignition switch.
Old Dec 18, 2018 | 02:32 PM
JagCad's Avatar
"Ground out" I don't get it.
From way out there I suspect one or both of the following:
1. Errant back feed. diode needed, not in the circuit.
2. Internal switch issue.
So, other than the white wire from the switch to the coil + poast, is there any other?
Carl
Carl
Old Dec 18, 2018 | 03:47 PM
stroud09's Avatar
Carl
Carl
Thanks for your quick reply. Just on my way out the door. I will try you when I get back home. It seems there is a green wire there somewhere. I will look again. Perhaps I could call you then take some picture? my number is 208 661 1997 I am in Yuma right now with the car and my RV. From Coeur d alene Idaho.
96x300
Mar 10, 2019 11:16 PM
Tbilisi79
Dec 19, 2018 06:29 AM
Taurus
Dec 3, 2018 06:06 PM
Andy Paine
Nov 19, 2018 05:43 PM
