I'm exhausted
Old Apr 4, 2020 | 03:20 PM
Darrenmb's Avatar
Veteran: Navy
Default I'm exhausted
Well, not me, car is, exhaust shop was.open, but had to make appointment. Still have to tweak ledt side to get it up further....
Old Apr 4, 2020 | 03:21 PM
Darrenmb's Avatar
Veteran: Navy
Old Apr 4, 2020 | 03:28 PM
Jose's Avatar
so it does work under the cage.
Old Apr 4, 2020 | 04:00 PM
Darrenmb's Avatar
Veteran: Navy
Yes sir, and the turbo mufflers are installed standing up in place of old resonators, fits quite well, stole the idea from lickahotskillets exhaust pics..
Old Apr 4, 2020 | 04:07 PM
Jose's Avatar
I suppose the neighbors will find another reason to complain now! Anyway, good job.
I hope you don't have any problem with speed bumps like the ones in Winter Park.
Old Apr 5, 2020 | 12:38 PM
JagCad's Avatar
Very neat work.
Yeah, I guess only time will tell as to muffler to ground contact at some places.
What does it sound like?
Carl
Old Apr 5, 2020 | 02:18 PM
Darrenmb's Avatar
Veteran: Navy
Sound depends on where you stand/sit.. outside of car in front its quite a deep tone, but not loud, standing behind the car, you hear the cam more, has a slight lope, but still not too loud, from inside the car its got a bit of a rumble, but nothing obnoxious, no drone, can hold a conversation or listen to radio... tried recording it, but loses a lot on the phone, sounds normal from back and up front all you can hear is air being sucked through the filter..
i am very happy with it!!!
All thats left now is the ac lines...
Old Apr 5, 2020 | 06:27 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Are those 2 1/4" pipes?
Dave
Old Apr 5, 2020 | 06:41 PM
mikega's Avatar
Wow, great job, well done
think of making a local exhaust for mine
Old Apr 5, 2020 | 06:48 PM
Darrenmb's Avatar
Veteran: Navy
Dave
yes!
Old Apr 8, 2020 | 08:06 PM
e015475's Avatar
Nice work on the exhaust.
If others are contemplating running theirs under the diff, this is a 2.5" exhaust that fits underneath a Jag IRS. Running a 28" dia.tire and I've not had any problems with speed bumps. This isn't a Jag car, but the diff sits at the same height as it would in a S3
If you're contemplating building an exhaust, the tube is all mandrel bends from mandrelbends.com (Columbia River Mandrel Bends).
The mufflers are cheap Dynomax 'turbo' mufflers and are pretty quiet without any drone. I made room for resonators, but after driving it a little I don't think I'll put them in.
The hangers are inexpensive ebay item. Don't know why, but they call them 'southern' exhaust hangers.
The exhaust tips are just a polished stainless mandrel u-bend cut it half and welded on to the mild steel tube with some nickle rod.. When it comes time to lump my S3 I'm wondering how to recreate that iconic 's' the Jag has with 2.5" mandrel bends - that would be cool.
I used ebay v-bands to hold it together. If you do this make sure you weld the v-bands clamped together in position or they'll be hard to get to seal. V-band that let you 'pilot' the tube into the mating flange work best.
Old Apr 9, 2020 | 12:24 PM
Roger Mabry's Avatar
If you would have used round Magnaflow mufflers they would not be hanging down in the resonator area..when I did the '72 LT1/700R I used the same type mufflers you used...I learned from that.
I never hit anything with the exhaust under the IRS. That car had the S shaped Jaguar tips added by necking down the muffler end to fit.. pitifully small but it looked good. Would love to be able to
have 2 1/4 sized tips made up like them for my current Jag that is overdue for the exhaust to be redone correctly.
Old Apr 24, 2020 | 07:10 AM
blot3.8's Avatar
Always a delight looking under a dry climate Jag and not seeing a hint of rust anywhere!
sunchip
Aug 28, 2023 09:21 PM
Darrenmb
Feb 1, 2020 11:42 AM
Prophizee
Apr 24, 2017 08:24 PM
Prophizee
Oct 18, 2016 03:39 PM
Stein Erik Hanssen
Photography
Aug 10, 2013 11:20 AM
