Intermittent brake problem.
Old Aug 14, 2025 | 06:51 AM
Billbuck's Avatar
Default Intermittent brake problem.
So I'm getting a random problem with breaking on my 1977 Daimler Double 6 XJC. The brakes appear to work fine but then randomly need a very heavy shove to come to a stop. After that they work fine again for a while then its shove/panic! Anyone had this issue and knows the cause?
Old Aug 14, 2025 | 10:19 AM
NBCat's Avatar
It may be an issue with the brake booster, or a vacuum leak.
Old Aug 14, 2025 | 10:58 AM
yachtmanbuttson's Avatar
At idle when you press hard on the brake pedal, does the engine start stumbling?
Old Aug 14, 2025 | 11:02 AM
Billbuck's Avatar
No. If anything the revs rise VERY slightly.
Old Aug 14, 2025 | 08:28 PM
Bill Mac's Avatar
You may have a partially/intermittently collapsed vacuum hose feeding the brake booster.
The hose may externally look OK but internally is coming apart.
I had a similar problem in a S3 XJ6 many years ago. A new length of hose is as cheap as chips
Old Aug 15, 2025 | 03:30 AM
Billbuck's Avatar
Thanks Bill, I will check. I assume you mean the servo or do you mean the reservoir under the wing?
Old Aug 15, 2025 | 08:26 AM
Bill Mac's Avatar
Bill
Both hoses
Roland M
Feb 23, 2015 11:54 AM
Running Man
Nov 9, 2013 10:04 AM
smgdata
Apr 23, 2012 04:09 AM
RICK
E type ( XK-E )
Jul 22, 2010 09:20 AM
