jaguar xj12l 1974
Old Jul 1, 2011 | 04:36 PM
alex-john76's Avatar
Default jaguar xj12l 1974
Hello
I have a jaguar xj12l 1974 and i have a problem with my strombergs-zenith.
I rebuilt them ( everthing new) and the car smoke a lot!!!
what should i do????
Old Jul 1, 2011 | 07:17 PM
alabbasi's Avatar
What color is the smoke?
Old Jul 2, 2011 | 04:08 AM
Hello and thank you for the reply. the smoke is black and only from the left exhaust.
Old Jul 2, 2011 | 08:04 AM
alabbasi's Avatar
Black smoke would indicate that you are running very rich. Try to lean out the mixture.
Old Jul 2, 2011 | 08:07 AM
How can i do that?
Old Jul 2, 2011 | 09:07 AM
alabbasi's Avatar
This may help.
zenith stromberg tech tips
Old Jul 2, 2011 | 12:01 PM
Thank you for the advice!
I will try this.
Old Jul 7, 2011 | 03:09 PM
Hello again.
I try to lean out the mixture but the problem still exists.
The motor works fine and accelerates perfectly.
What else sould i do?
Old Jul 8, 2011 | 05:41 AM
Fraser Mitchell's Avatar
It souns like it's flooding from one or both carbs on that side, so if adjustment doesn't work, you'll have to take each one off and check the float bowl - did you replace any parts in this area ? I don't know anything about Strombergs, only SUs, but floats can, over time end up not floating properly, even filling with petrol due to a small leak if made of brass.
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
