Limp Mode 1990 XJ6
Old Mar 26, 2008 | 01:11 PM
Frankie's Avatar
Default Limp Mode 1990 XJ6
I have been dealing with the limp mode coming on and off. I replaced the transmission control unit under the pass. side dash ( it was used) The old control unit DBV5080 would not come out off limp mode at all. Sometimes when you turn the key on and off it will go out of limp mode for a very short while.Cleaned the cable ends with WD40 on the electrical hook up to the trans on the left side. What next??? Thanks all....
Old Mar 26, 2008 | 07:25 PM
jag_genius's Avatar
Default RE: Limp Mode 1990 XJ6
may be a code for the trani.. you will have to go to a dealer that still has and uses PDU which is a old diagnostic reader... i remembering using it on a 1990..
Old Mar 27, 2008 | 09:46 AM
ken@britishparts.com's Avatar
Sounds like you need to adjust the rotary switch. Driver's side of the transmission.
Old Mar 27, 2008 | 12:28 PM
Frankie's Avatar
The on board computer reads: Fuel 69
Old Mar 27, 2008 | 12:31 PM
Frankie's Avatar
Old Mar 28, 2008 | 01:02 PM
Frankie's Avatar
I read your description that you gave to Russ on 9/11/2007...I'll try the rotary switch twist tomorrow..Thanks
Old Mar 28, 2008 | 03:35 PM
I also sent a PM to you.
Forcedair1
Sep 8, 2025 01:57 PM
tomsjag
Jun 10, 2023 10:02 AM
Forcedair1
Feb 19, 2020 01:51 PM
shootingbrake
Sep 23, 2015 10:54 AM
tsimms7
Sep 15, 2015 12:43 PM
