Loud tapping. dosent sound good
Old Aug 4, 2007 | 09:30 PM
1badjag's Avatar
Default Loud tapping. dosent sound good
Im hearing loud tapping form the top of the valve cover people say its normal but i dont think it is by any means. Its not regular valve tapping. its alot louder. Makes it sound kinda like a diesel.
Old Aug 4, 2007 | 11:13 PM
Jose's Avatar
Default RE: Loud tapping. dosent sound good
what year?
Old Aug 5, 2007 | 03:45 AM
1badjag's Avatar
1990 xj6 4.0
Old Aug 5, 2007 | 09:21 AM
Jose's Avatar
it could be a timing chain if you can't pinpoint the exact side where the noise is.
Here's a Low Tech way to try to pinpoint the noise: start the engine, get a long piece of wood, (a broom stick without the broom works well), place one end overa valve cover, the other end to your ear, this will transmit the noise to your ear without any risk of damaging your ear drum. Do it on each valve cover.
Keep your hands away from the BELTS, FAN,and ANY MOVING PULLEYS.
Old Aug 5, 2007 | 06:32 PM
ORIGINAL: 1badjag
1badjag.........have you checked? Maybe it is a diesel....
Sorry bro, couldn't resist
Jim
Old Aug 6, 2007 | 05:20 PM
ken@britishparts.com's Avatar
Does it get wore as you rev the engine? There is a replaceable timing tensioner on the right side of the engine. Easy job if it's the cause.
Old Aug 6, 2007 | 07:11 PM
1badjag's Avatar
it dosent get worse..... it just tapps faster along with the rpms
Old Aug 6, 2007 | 09:05 PM
bigdreams05's Avatar
LMAO!!!! Yes ken, it gets worse as you rev the engine!
Old Aug 7, 2007 | 11:07 AM
Behind the distributor (yes, XJ the distributor again) you will see a plate with two bolts that lines up with the timing chains. Check to see if this is where your noise comes from. Jaguar updated this tensioner. Send a PM about parts, etc.
way2far
Aug 31, 2022 09:26 AM
mbergen
Oct 23, 2019 10:26 PM
JagBrian
Aug 18, 2019 05:07 PM
redrover41
23
Sep 25, 2015 01:33 PM
XJsc-guy
Sep 2, 2015 11:43 AM
