Lowering 1976 XJ12C rear
Old Nov 11, 2015 | 10:06 AM
cliffb422's Avatar
Default Lowering 1976 XJ12C rear
I need to lower the rear only on my 1976 XJ12C probably only 1" to 1 1/2".
What is the proper procedure to not upset the alignment?
Thanks for any help. Cliff
Old Nov 12, 2015 | 07:10 AM
pnwrs2000's Avatar
I'm not familiar with XJC's but i assume they're the same setup as a normal XJ ?
Anyway, on my XJ6 im going for 4 adjustable platform coilovers, probably from either Gaz or Bilstein.
Failing that you could always get a fat person bundled into the boot but this would have some disadvantages
Old Nov 12, 2015 | 09:15 AM
JagCad's Avatar
Way back, some, not I, in other critters merely added a couple of sand bags in the boot!!! Sounds awful, and it is, to a point. But, it does add balance to anose heavy car!!!
Tail draggers were in "fashion"....
Moving the lower coil over attachment points on the cage downwards????
Carl
Old Nov 12, 2015 | 07:00 PM
Daf11e's Avatar
Carl I can so relate to that........back in the sixties as a teen I remember throwing dads cement bags in the back of an s series valiant to keep the a$$e down...........those were the days, no expense spared
andyXJR
Nov 25, 2015 10:42 AM
Aaron 3.2
Nov 11, 2015 11:37 AM
Fstbmw1
Nov 10, 2015 10:51 AM
ChrisJay
Nov 10, 2015 10:46 AM
camuar
Nov 5, 2015 12:26 AM
