Lowering xj40
Old Jan 30, 2014 | 02:49 AM
xj40cruiser's Avatar
Question Lowering xj40
I've only had my 1987 XJ40 XJ6 Jag for a couple of week now and want to start customizing it. One thing that i've noticed is that not many people have been lowering these cars. Whilst searching around endlessly I cannot seem to find lowering springs anywhere. I really would like my jag to be a but different to others with a lower wider 'stance' that will almost seem hot rod/cruiser influenced.
So really my question is, Have people lowered these car? Is it hard? How did they lower it?
Cheers guys,
Old Jan 30, 2014 | 08:43 AM
icsamerica's Avatar
Default Incorrect forumn but...there are not many options....
There are not many options outside of custom springs or cutting the springs you have. I don't recommend because cutting and custom springs will be difficult for a enthusiast to get right. These cars are already kind-a-low to begin with. You may be able to get the look your after with bigger wheels and tires. Larger diameter wheels and tires give subtle a lowered look and fill out the fenders a bit more which creates a contemporary sculpted look. Do some test fits with some larger wheel and taller tires and you will see what I'm talking about. The jag has a chevy bolt pattern so you've got lots of wheel options.
Old Jan 30, 2014 | 07:53 PM
Ok.. well I know that there are many companies that make springs for other model jags around this time period. Are the springs interchangeable with other Jaguars?
Old Jan 30, 2014 | 09:39 PM
AristoCat's Avatar
Junk yard a couple sets of springs & start experementing.
When modifying springs, understand that you might be stepping into a project & might have to modify things, other than the springs themselves.
When cutting springs, try to generate as LITTLE HEAT AS POSSIBLE!!!
Even a slight ammount of heat will change the spring's temper.
Old Feb 6, 2014 | 02:09 PM
ronbros's Avatar
i took the plastic spacers out dropped it about an inch.
for the front some guys add steel spacers between the a-arms and spring seat, i'm guessin a 1/2" spacer would drop it more than a 1/2, becareful.
use new grade 8 bolts and lock nuts.
pic ; low and wide, V12
Old Feb 7, 2014 | 07:48 PM
on edge's Avatar
I used 12mil spacers between my a arms and spring seat on my xjs and my series 1 this lowered the front by 20 mil and had rear springs made to suit. XJ40 should be similar to do.
Cheers Ray
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
MrWhite
33
Oct 22, 2015 10:29 AM
Delta66
Oct 4, 2015 05:40 PM
