Lumping the A/C Compressor
Old Jul 29, 2020 | 09:35 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Default Lumping the A/C Compressor
Will my new GM A/C compressor need to have a relay added to the clutch control wire from the Delanair 2? There are four (I think) relays in the unit, but I'm not sure they are used to latch the compressor clutch. The clutch is just a big electro-magnet and I would think it doesn't require much current to engage, but I could very well be wrong. I am not going through the GM PCM to control the A/C, I will leave it to the Delanair to do what it has been doing, just for a different compressor.
Any flies in this ointment?
Dave
Old Jul 29, 2020 | 11:12 PM
Doug's Avatar
I would't worry about adding a relay unless there's some reason to think the clutch on the new comp will draw more than the old one. And I can't think of any reason it would.
Old Jul 30, 2020 | 03:17 AM
LT1 jaguar's Avatar
Thanks Doug, that's kind of what I was thinking but I've had no experience with that issue.
Dave
Old Jul 30, 2020 | 06:09 AM
Darrenmb's Avatar
Veteran: Navy
I have added a relay, however not to operate the compressor, mine is spliced into the compressor 12 volt feed, and actually throws a ground over to the relay for the high speed cooling fan, found the diagram for this on shbox.com.
or domyou have a different setup.in mind to control the cooling fan without using the pcm???
Old Jul 30, 2020 | 06:13 AM
Darrenmb's Avatar
Veteran: Navy
Old Jul 30, 2020 | 10:40 AM
LT1 jaguar's Avatar
I'm going to use a separate fan controller with adjustable on/off temp from Flex-a-lite. It also has the capability of turning on with the A/C, but I haven't considered that yet, the way you set yours up is probably how the instructions will say to wire it. I plan to have a switch in the console to turn the compressor on/off and a couple of other things in the Delanair unit.
Dave
jerry_hoback
XJ40 ( XJ81 )
Jul 31, 2020 11:07 PM
Wascator
Aug 3, 2013 10:05 PM
disguay
Dec 15, 2012 04:21 PM
prrthdtx
Nov 24, 2010 08:01 AM
Bauldee
Aug 14, 2009 05:06 PM
