Manual gearbox will not reverse
Old Nov 11, 2019 | 10:24 PM
Hardi Tirtakusuma's Avatar
Default Manual gearbox will not reverse
*Solved*
Seems I need to push a bit hard to left, while engine is idling...
Hi all,
This is my first day owning my S1 manual transmission. Pardon me for this basic question!
When i tried to engage reverse gear, it won't let me engage.
Manual book says i have to push the lever against spring pressure and pull to reverse position.
Seems I can't push it to the left or push down.
Is there any locking mechanism i need to "touch"?
Last edited by Hardi Tirtakusuma; Nov 12, 2019 at 03:35 AM. Reason: Issue seems to be solved
Old Nov 13, 2019 | 12:50 AM
The Mekon's Avatar
Hardi - it has been a long time since I drove a Jag of your vintage with a manual box. But I seem to remember anyone else who drove my 1970 E type also had problems getting reverse. As I recall, my method was to take a running swipe to the left with my hand, and it would enter the gate then pull back. So try that, and also ensure your clutch is properly disengaging - pump it if need be.
Old Nov 14, 2019 | 04:03 PM
rustfreemike's Avatar
Originally Posted by Hardi Tirtakusuma
*Solved*
Hi all,
I have a S1 XJ6 with manual O/D gearbox as well. There is no reverse lockout as you have seen but with wear sometimes it can be a bit tricky to engage reverse. Obviously you need to be completely stopped and idling but if reverse gives you trouble, you can select 1st and then go into reverse. I've found this helpful.
Old Nov 18, 2019 | 11:01 AM
JagCad's Avatar
Never did drive this version of a stick shift. And, the last was a very old one. 39 Ford.
Reverse has no synchros to assist the shift.
To the contrary, it is designed to make it a bit tricky to shift in to reverse, and as such prevent inopportune thigs from taking place. Could be considered a sort of safety lock out.. .
Glad you mastered it. Enjoy the critter..
Carl
Galee
Sep 30, 2019 03:52 AM
hooter
Aug 2, 2015 10:12 AM
osagie
Oct 3, 2014 07:02 PM
sowyers
Feb 21, 2014 10:51 AM
Jaggyx
Jan 25, 2010 11:42 PM
