Manually turning over a V12
Old Dec 7, 2011 | 09:00 PM
tizzle's Avatar
Default Manually turning over a V12
Hi All
This may sound like an obvious question to many but it's not something I've had to do to date!
What is the best way of manually turning over a V12 (circa 1989, carburetor)? I am assuming it's a case of using a wrench on the crankshaft but would appreciate any do's / dont's / gotcha's.
Also, what size socket is required?
Old Dec 8, 2011 | 04:58 AM
32mm rings a bell, been a looooooong time since I needed to do that.
DO NOT rotate the engine BACKWARDS (anti-clockwise). Timing chain tensioner damage (HUGE $$$$) may occur. Note I said MAY, as some have done it and no snapping sound of the plastic tensioner, I have NEVER been so lucky. So if timing it this way, and you go past your mark, dont be lazy, GO ROUND AGAIN, its only 12 cylinders.
Other than that, not rocket science.
Old Dec 8, 2011 | 06:47 PM
tizzle's Avatar
Again, thanks Grant.
Do they turn easy - I imagine it taking a fair bit of effort for an engine that size?
Old Dec 9, 2011 | 02:00 AM
NO.
My wife used to turn any of ours whilst I watched the timing marks from down under, and no effort at all. Our HE's are all 12.5:1, so a bit of resistance as comp comes up, but we use a 24" breaker bar, and dont rush it, and as I said NO issues.
Couple of stubbies for inner lubrication makes it sooooo easy.
Old Dec 9, 2011 | 10:20 PM
tizzle's Avatar
Hmm, hadn't thought about the stubbie option. Obviously an essential piece of equipment for this type of work!
aholbro1
Dec 29, 2024 06:46 PM
Doug
Feb 27, 2019 01:31 AM
Sambo21
Nov 19, 2015 03:55 PM
jagent
Sep 7, 2015 05:00 PM
1100me
Sep 7, 2015 06:26 AM
