More Ignition timing???
Old Jul 6, 2021 | 07:10 AM
iramphal's Avatar
Question More Ignition timing???
Now I'm totally confused. I timed my S3 XJ6 with thr strobe hooked to # 1(Firewall end).
On "Living with a Classic" link below, he says to time it with the light on #6 (near the Fan).
This should not make a difference Right?
Ian
Old Jul 6, 2021 | 07:19 AM
Doug's Avatar
I've always used #1 but some use #6. They're at TDC at the same time.
Old Jul 7, 2021 | 07:19 AM
iramphal's Avatar
Doug, what am I missing? Although both #1 and #6 are at TDC at the same time, only one will have a spark. So with my light on #1, I get a spark that lights up the timing plate. Surely if I attach it to #6, it should be 180 deg. off?
Old Jul 7, 2021 | 12:52 PM
David84XJ6's Avatar
360 degrees behind #1 spark , same spot on crank timing damper.
dirtyharry
Apr 21, 2021 09:13 PM
dirtyharry
Mar 23, 2020 09:36 AM
yachtmanbuttson
Jul 1, 2018 06:17 AM
iramphal
May 4, 2018 10:14 AM
Executivekev
Sep 16, 2010 08:15 AM
