more problems + over heating!
Old May 27, 2009 | 08:16 PM
1985jag's Avatar
Default more problems + over heating!
after putting my vehicle on the road i go for a 1mile drive home 5 min in this city. and almost home the car starts getting hesitant. i barly make it home and she stalls dead after a struggle to stay running. i lift the bonnet because i can smell the issue already sure enough a but of coolant has belched out on top of that i find a broken expansion tank a loose spark plug with a burnt up wire. and a small amount of oil around plug 1.
car has not ran for 7 years so i expect problems.
here is what i have found so far:
Replaced fuel pump.
bad plugs and wires.
over heating: trying thermostat.
starts hard.
rotten gas tanks.
broken stud on wheel.
both front markers are shot.
had a flat.
rusted out fenders and floors.
no wipers or interior lights or power windows.
3.5 gal of oil was in the engine.
Old May 27, 2009 | 08:53 PM
Doug's Avatar
Hate to say this, but....
Are you sure the 3.5 gallons of oil was all oil, and not a mixture of coolant and oil? If there's coolant in the oil you probably have a blown head gasket....which goes along with the overheating
Old May 28, 2009 | 06:12 PM
1985jag's Avatar
no its weird it was all oil the stick said it was that full but i didnt believe it untill it came out thick and black suprisingly no trace of coolant and the oil level is fine now that i replaced it. also i am sure the radiator is full because i have a broken expansion tank and i over filled it and coolant came rushing out of the return line because thats where it broke.
i am going to try the thermostat when i can afford one. and im hoping that the new plugs will show improved starting then again my no6 wire socket looks a little scored. and another problem i founs 3 out of six plugs were finger tight. i have to wait for the battery tonight but i will post everything.
Old May 29, 2009 | 09:49 AM
Kamak86's Avatar
Careful with the Thermostat, I took off a bolt head trying to replace my thermostat. Mines an 86 Xj6 that sat for 2 years until I got a hold of it.
H20boy
Dec 24, 2024 03:23 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
Bcrary3
Sep 3, 2015 03:48 PM
laserguy
Sep 3, 2015 02:02 PM
