My 1970 Daimler Sovereign
Old Jan 25, 2013 | 05:32 PM
mickvic's Avatar
Originally Posted by pugaree
And I have just completed the exhaust system. Consists of a new set of headers into a sigle collector then back in to a twin system with mufflers. The exhaust place has done a magnificent job and the sound of the motor now is really nice.
Rather than routing the exhaust back through the diff cage and near the brakes, I was talked into having the pipes run under the diff, there is minimal heat transfer, have never hit anything and are very easy to remove if I ever need to take the rear assembly out again. I have seen quite a few exhausts done this way now and none have had any problems.
My '71 S1 xj6 has the pipes coming straight out, I wonder when the pipes changed to the curved s shape , why, and were they only like this on daimlers at the time?
Old Jan 25, 2013 | 06:42 PM
pugaree's Avatar
From what I have read, straight pipes were installed on the first cars but there was complaints about exhaust gas being sucked back in to the car, so Jaguar changed to the curved pipe so the gases would escape the vehicle better.
Old Jan 27, 2013 | 07:19 AM
SafaJag's Avatar
Exactly right - and I recently read somewhere that the change was made in the late S1 cars.
Cheers,
T.
Old Jan 27, 2013 | 12:15 PM
Jose's Avatar
back in 1991, I installed 1988 XJ-40 "rolled" SS straight tips in my '84 XJ-6 and I loved the look; I took the picture below before I had a digital camera, so the quality is terrible, but you can see a little of the XJ-40 straight tips. I had no problem with the exhaust being drawn into the cabin at all with the straight tips. When I replaced the two rear resonators, I went back to the original "S" tips, but I still have the XJ-40 tips which I'm planning on re-installing.
if you want a less pronounced "S" look, somewhat between a straight tip and the original "S" tips, try the 1985 XJ-S Coupé tips, I also have a pair of those and they are a bit straighter while still retaining the "S" shape. I'm planning on installing those in my '65 S type.
Old Mar 7, 2013 | 04:45 AM
66VDP's Avatar
Thumbs up Canberra Daimler
Hi,
Nice work and looks like you've put some hard work in.
I recently bought a Series I Daimler in the same color and also with a factory sun roof. It's the Double Six Vanden Plas model.
Needs some body work and a repaint but she is registered and drives well. I'm on the eastern side of Canberra if you're interested in catching up sometime. I'm not involved with any clubs yet but thinking about it.
Cheers.
Old Mar 7, 2013 | 05:32 AM
I ran a Series I Daimler Sovereign in 1972 with 'S' exhaust trims and a colleague had the equivalent Jaguar with straight trims. l recall an issue with the exhaust trims at the time.
In our damp Northern climate, Jaguars always put out steam from the exhaust on startup. With the straight exhaust trims, this would discolour the chrome over riders and the underside of the rear bumper with surface rust setting in quite rapidly. The 'S' shaped trims minimised, although didn't entirely prevent, this from happening.
Old Mar 7, 2013 | 03:12 PM
Ahabiam's Avatar
Really nice ride!
Old Mar 8, 2013 | 04:56 AM
  #28
pugaree's Avatar
Originally Posted by 66VDP
Hi,
Cheers.
Sounds great, would love to to catch up and see the V12. I'm down in Tuggers, happy to PM my address if you want to come down for a beer and a chat.
Old Mar 8, 2013 | 05:16 AM
66VDP's Avatar
Excellent. Unfortunately the V12 has been replaced with a Chev V8 but it's still a nice car. Needs some work, though from what I have seen of your car you will be a wealth of knowledge. will be great to see another series 1!
Attached Thumbnails My 1970 Daimler Sovereign-59c6c8ca-c0cb-4d2a-bf90-65371bcaaba2-1624-0000035533d59c83_zpsafd4f840.jpg
Old Mar 8, 2013 | 09:47 AM
  #30
anjum's Avatar
That's one lovely car! sorry, cat!
Old Mar 8, 2013 | 10:20 AM
  #31
trymes's Avatar
Both Daimlers are excellent looking specimens!
66VDP: Looks like your car has the same vinyl top and Weathershields sunroof that my '71 XJ6 does. Unfortunately, my sunroof is loose and rattly up front, both the latch itself, and the connection between the outer layer and the forward cross-bar that holds the latch.
Off to search for more information on that front!
Tom
Old Mar 8, 2013 | 05:51 PM
  #32
66VDP's Avatar
Default Canberra Daimlers
If you can send through your address that will be great. Not sure if my PM's work yet as I'm a new member but we can try. Otherwise I can give u an email address.
Thanks, Dan.
Old Mar 8, 2013 | 05:57 PM
  #33
66VDP's Avatar
Tom
Thanks Tom,
Yeah the same type of vinyl. Have you had new vinyl put on? I'm planning to replace mine as its looking old but not sure where to go for a quote. Good luck with the rattle
Old Mar 9, 2013 | 06:29 AM
  #34
pugaree's Avatar
Thanks, Dan.
PM sent.
jimforrest (uk)
Feb 28, 2019 06:42 PM
SCMike
Nov 25, 2015 07:55 AM
muntasarz
Sep 29, 2015 08:20 PM
Harry Dredge
Sep 5, 2015 02:44 AM
