My return to jaguar Forums
Old Jul 10, 2023 | 01:25 PM
JagCad's Avatar
Default My return to jaguar Forums
Forum members:
Thanks to Elinor and whomever she enlisted to fix my issue so that I could not fix. Change my password and enable me to log in here.
I have a password, i tried t change it to one that was easier fr me to use. no luck. no biggie. I will use what I got. it works, I am back !
Thanks to those that pulled this off!!
Jaguar content. My car had starting issues. My son gave me a hand we found the fault. A failed wire splice! Not in the Jaguar part. But, in the GM harness.
We had a "discussion" . He advocates crimped splices. I like solder? ?
For nolw, as i could nt find tat box, it is twisted and taped. I found the box of connecors. but, I tried a pair on my grinder termonals. N go. hence, on my list to solder.
My bnch grinder has Lucas like electrical issues. I suseced first the plug. i brke. i replaced t. still no go. Thn, opened t and bridged the sewitch. here, I fu that if i touched one wire that went to the swtch togroud, it rn??? Ths can not be. Un bolted t from te bench to access the underside. next session. See what in h.. s ging on there?
or, is it, anther fom amazon?
A cas od fixing a toll so i culd fix another. My bandsaw awaits,,, i neede a grinder to shape a new guide fr the blade.
Thanks again. off tl the garage.
Carl
Old Jul 10, 2023 | 04:37 PM
Darrenmb's Avatar
Veteran: Navy
Welcome back Carl!!!
Old Jul 10, 2023 | 09:20 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Originally Posted by JagCad
Forum members:
Carl
Glad to see you back in the fray, Carl. I'll throw my 2 cents here in favor of properly crimped splices. By proper, I mean correct size connector, correct crimper, cover the splice with a length of heat-shrink. I suck at making solder splices, don't know why, just luck I guess.
Dave
Old Jul 10, 2023 | 11:09 PM
Daf11e's Avatar
Good to hear from you Carl !!!!
Old Jul 11, 2023 | 05:27 AM
Welcome back Carl,
Forum owner Internet Brands sent me a confirmation they'd reset your password. Good to see it works!
Old Jul 11, 2023 | 08:27 AM
YAAAAYYYY CARL!!!
I'm SO glad it worked for you!
Old Jul 11, 2023 | 04:37 PM
sanchez's Avatar
Welcome back Carl!
Old Jul 16, 2023 | 01:39 AM
yarpos's Avatar
You could compromise and use those fancy smanchy crimp/seal/solder do hickeys (technical term) Then everybody has had a go :-)
An example from a random search
https://www.grote.com/electrical-con...tt-connectors/
Old Jul 16, 2023 | 03:05 AM
Bill Mac's Avatar
Welcome back Carl
Properly applied crimp splices are far better than soldered connections. They are extensively used in aviation electrics.
Soldered joints do work however the "hard" ends of the solder joint where the solder finishes are a potential source of failure especially in areas where the wire can flex.
The best way to avoid this is to apply a double coat of heat shrink tubing. ie first coat shrunk then followed by another coat.
That gives the joint some protection against flexing and ultimate failure.
Peter_of_Australia
May 17, 2023 10:56 PM
Max's dream car
Dec 11, 2020 07:12 AM
Segfault
Jul 18, 2018 03:59 PM
Butch01
Jul 3, 2017 07:59 PM
Einhead
Jul 3, 2017 04:27 PM
