My XJ6 Paused
Old May 25, 2010 | 06:01 AM
Robert's Avatar
Unhappy My XJ6 Paused
My 1990 XJ6 decided to take a pause last night. I had come home from work and parked her outside for about an hour when I needed to run an errand. We pulled out of the cul-de-sac, and started to accelerate in a right turn and I had one of those empty feelings in my stomach when everything went quiet for about a second as the engine died. It happened so suddenly that I didn't have the opportunity to check the gauges. I let up on the accelerator and she caught and we drove on.
Any thoughts on what could have happened?
Old May 25, 2010 | 01:25 PM
ken@britishparts.com's Avatar
Did you lose the lights as well? If so, I would suspect the ignition switch. If not, perhaps the engine wiring harness has a weak point. I also had this happen to me due to a hole in the air intake hose, it cracked inside the accordion hose and was damn near impossible to find.
Old May 25, 2010 | 02:42 PM
mysterygrl's Avatar
Veteran: Coast Guard
Ken, please look at my post regarding my XJ6 and an Electrical Harness...posted earlier today...thanks
Old May 26, 2010 | 06:04 PM
Robert's Avatar
It was daylight, Ken, so I didn't have the lights on. And it happened so quickly, that I don't remember if the radio died, or not. I hope it doesn't happen again, but if it does I'll try to remember to see if the radio dies.
Old Jun 11, 2010 | 07:02 PM
poor boy's Avatar
Robert, did the car pause again after the first time and if so, was it on a corner again?
Old Jun 12, 2010 | 09:55 AM
Robert's Avatar
Yes it did, poor boy. Only this time it was while traveling in a straight line coming to a stop. Very strange. The engine stopped for maybe two or three seconds. I never lost electrical power; the radio kept playing and the lights never went out. After those two or three seconds, it continued on as though nothing had ever happened. Very strange.
Old Jun 13, 2010 | 09:14 AM
poor boy's Avatar
Default paused
I know this is going to sound rediculously simple but have you checked your fuel filters? The other thing, not so pretty, have you pulled a fuel pump pressure test? I had a fuel pump just starting to drop pressure on my "Vette" and it did the same thing and would generate almost a fluttering at high RPMs. Just a place to start.
Old Jun 14, 2010 | 11:19 AM
These are just guesses:
1. Check for any holes or cracks after the airflow meter and before the throttle body.
2. See if the back (electrical portion) of the ignition switch has become loose. This can cause momentary lack of contact--but usually the whole car dies then comes back.
3. Wiggle the wiring harness on the engine. These poor guy is getting old and brittle.
King Charles
Oct 16, 2015 01:25 AM
trickeyM
Oct 4, 2015 05:43 PM
wonderwire
Oct 4, 2015 05:41 PM
baskervillema
Oct 1, 2015 06:43 PM
dansxj6
Sep 28, 2015 08:02 AM
