Mysterious Lever and button
Old Jun 5, 2020 | 02:07 PM
JagfrmDad's Avatar
Default Mysterious Lever and button
While I await the arrival of our manual hoping this forum can help me identify a few things on the car. There’s a lever on the left drivers side under the panel that fees like when you push it it goes into four different positions. The second thing is the button looking thing on the floor by the brake.
thank you in advance. Learning a ton from this group!!
Lex
1973 Jaguar XJ12
Old Jun 5, 2020 | 02:09 PM
Doug's Avatar
Floor button = dimmer switch I reckon
Lever = manual choke, perhaps? Looks like the knob/handle is mssing
Old Jun 5, 2020 | 03:24 PM
JagfrmDad's Avatar
Default Ty
Thank you so very much!!!
Old Jun 5, 2020 | 04:15 PM
Yellow series3's Avatar
Excuse me for smiling. As our world changes, society forgets things. When I was young every American car had the dimmer switch on the floor. Of course, most of my generation have no idea how to use Twitter either. Glad you are going to take care of your father's car, Lexi. The folks on the Forum are here help.
Old Jun 5, 2020 | 05:41 PM
JagfrmDad's Avatar
Default So grateful
Thank you. Glad you’re smiling! When my grandfather gave it to my dad I called dibs immediately. So with both of them gone and me knowing nothing about cars figured I could take up a new hobby and finish my dad’s work to get it back to beautiful.
So appreciate everyone’s help.
Lex
Old Jun 5, 2020 | 10:00 PM
"Lever" looks to me like the hood release.
Old Jun 6, 2020 | 01:30 AM
o1xjr's Avatar
If the lever has four different positions it could be the fresh air vent. Pushed in is closed, pulled out is fully open.
Old Jun 6, 2020 | 08:36 AM
The large black lever that is slightly curved and pointing down is the hood release as Elinor said. The gizmo beside it with a white cylinder, no idea. But as stated above, that is where the fresh air vent pull knob is located. The air enters through the little mesh grills over the outer headlights. You can test the vent by having someone hold a leaf blower on those vents over the headlights and then feel the air coming in on the outer side of the footwells.
Jeff
Old Jun 6, 2020 | 08:43 AM
Be sure to check out the YouTube channel Living with a classic he has tons of easy to follow tutorials on your car. Be sure to watch the one on replacing the rubber hoses on the fuel rail on top of the engine. The rubber gets old and brittle and if it gets a leak it sprays gas. Not a good thing.
Jeff
Old Jun 6, 2020 | 10:06 AM
David_h's Avatar
Here is the arrangement on my car. The fresh air knob is aligned horizontally. On XJ6 with strombergs when you pull the choke lever it pulls twin cables, one for each carb and also illuminates the dash light which we identified in you other thread post. The floor button is dip switch or high beams.
Old Jun 6, 2020 | 10:10 AM
Never mind.
Rostman
Nov 30, 2020 07:41 AM
Josue Ferreira
Aug 23, 2019 12:15 AM
MR-tin
Jun 18, 2019 06:43 AM
Mark D
May 24, 2018 05:18 PM
tonyT941
Mar 30, 2010 09:48 AM
