Name That Intake Sensor
Old Oct 25, 2022 | 07:44 AM
MSGGrunt's Avatar
Default Name That Intake Sensor
I did look, but couldn't find any picture that list what each of these sensors is and or a part number.
Old Oct 25, 2022 | 02:01 PM
MSGGrunt's Avatar
#1 EAC1385.
The one closest to the radiator is the thermo time switch, this is only operational during while the starter circuit is engaged. It checks if you are starting a cold engine or not and allows the cold start injector to supply extra fuel if needed. These are not easy to find any more.
#2 071-241 (Moss Motors) Temperature Transmitter (Temp Gauge)
The second one back with the single spade connector is the sender for the coolant temperature gauge on the dash, these are easy and cheap to replace.
#3 EAC3927. Coolant Sensor.
The third one back is the coolant temperature sensor for the electronic fuel injection, its job is to tell the ECU to allow a richer mix if the engine is not fully warmed up, at about 180 degrees F. This has little to no effect on the fuel mixture. This is cheap and easy to replace. If you are running rich and you think it might be this sender then your engine should only be showing symptoms of a rich mixture while warming up.
#4 EAC3762. Thermal Switch.
The fourth one back is a sender for the emissions control system, I've heard that it may have something to do with the AC?
Old Oct 30, 2022 | 09:45 PM
retroren's Avatar
Thanks for the comprehensive explanation and photos. I greatly appreciate it.
kl3vr
Nov 5, 2020 08:11 PM
Col. Sandurz
Dec 22, 2016 09:10 PM
mhamilton
Jul 10, 2013 08:01 AM
jonsjag
Feb 10, 2011 11:06 AM
jagpro69
May 3, 2009 06:32 PM
