Need help with tappet stakedown kit
Old Oct 17, 2012 | 06:29 AM
  #41
Jose's Avatar
all XK engines sound their ticking during startup, announcing they have "awakened", and all Injectors have a ticking sound too. Just keep the engine oil fresh and checked.
Old May 18, 2013 | 08:56 AM
  #42
Woznaldo's Avatar
Hey Guys,
I had a leaking Cam Cover so decided to pull it off and take a look underneath. I could see that all bar the forward two Tappet Sleeves had received some kind of contact damage from the Camshaft. I already had a stake down kit ready to go, so set about cleaning it all up. This is when I found a piece of Tappet Sleeve shrapnel from the rear most Ex Valve.
I'm going ahead with the stake down kit to stop matters getting worse, but I'm worried that the 1/4-28 UNF Cap Screws that have been supplied aren't up to the job? Should I go with 1/4-20 UNC instead?
Has anyone used UNF and had bad experiences?
Old May 30, 2013 | 11:25 PM
  #43
Woznaldo's Avatar
Went with the 1/4-20 UNC Cap Screws and everything is holding well.
I my luck would have, I've now found a coolant leak somewhere near the back of the Head/Block!.......
kthrash
Feb 25, 2019 10:20 AM
Johncy2000
Oct 2, 2015 01:05 AM
pnwrs2000
Sep 30, 2015 01:56 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
