Need some help tackling S3 steering rack rebuild
Old Aug 18, 2024 | 01:23 PM
nsogiba's Avatar
Default Need some help tackling S3 steering rack rebuild
Hi all, I'm finally tackling my steering rack rebuild in my '84 S3. I have it all blown apart on the bench now and am having trouble locating a replacement seal in my kit for the following component/bore:
Here is the seal that I removed:
Here's what came in the kit, which is FVP 9103 from Rockauto.
I couldn't match up the offending deal with anything in the kit. Are these available separately?
Old Aug 24, 2024 | 08:31 AM
nsogiba's Avatar
A swing and a miss on the pinion seals. I must have expanded the blue pinion seals too much with the plastic because I wasn't able to get them to contract enough to avoid being nicked.
I have another seal kit on the way. Any tips to prevent the same issue?
Damaged noted on the tube/rack seal, probably during disassembly
Last seal left in the kit...where does it go? Big fat o ring.
Old Aug 24, 2024 | 12:01 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Take a look at my thread, posts: 65 and 143. May help you out.
https://www.jaguarforums.com/forum/x...j6-lt1-211881/
Dave
Old Aug 25, 2024 | 08:19 AM
Darrenmb's Avatar
Veteran: Navy
I had every intention of rebuilding mine, until I found one on rock auto! Lol, I did have to swap out the inner tie rods on it, but I was back on road in just a couple of hours!! Still have original on a shelf
Old Aug 25, 2024 | 11:16 AM
nsogiba's Avatar
Would have loved to just swap one out, but Rockauto shows out of stock on all models.
Old Aug 28, 2024 | 07:30 AM
nsogiba's Avatar
Last night I got the new seal kit in and got to work. If you don't respect the learning curve it can get expensive buying new seals, so some research indicated that resizing teflon rings is a common practice.
I started by getting a rough measurement of the OD of the spool lands.
And then transferred that measurement to my seal sizer, onto which I stretched the teflon pinion seals after soaking them in hot water for a bit.
The seals went onto the pinion valve easily, and I then installed my seal compressor to shrink them back down.
Installing the rack tube seals
Centering the rack bar after the housing and ends were assembled - 3/16" bit.
My solution to rotating the pinion. Worked perfectly with no damage.
Rack is back in the car and plumbed, test fire in a few days...
Old Aug 28, 2024 | 07:38 AM
nsogiba's Avatar
This was my first time rebuilding a steering rack and it was easier than expected, just required attention to detail and cleanliness. The only special tool that I needed to buy was a spanner wrench which I got on Amazon.
I found the following links particularly helpful.
This video was great for reassembly:
Instructions for a similar Triumph rack
https://triumphowners.com/resource/p...-instructions/
https://s3.ap-southeast-2.amazonaws....ck-Rebuild.pdf
Schematic:
https://parts.jaguarlandroverclassic...e=C06572794813
Seal shrinking technique:
https://www.jaguarforums.com/forum/xjs-x27-32/rack-pinion-seal-kit-installation-advice-needed-217567/
https://ls1tech.com/forums/automatic-transmission/1554005-how-install-teflon-seals-without-tools.html
Hope this helps someone in the future. I would have really loved to just swap the rack with a reman but everything seems to be NLA from the typical commercial sources like Rockauto, Advance Auto, Autozone, Napa, and O'Reilly. The prices for a reman rack from the Jag specialists were high enough that I tackled the rebuild myself.
Toby123
Nov 14, 2025 01:09 PM
gulley67
Sep 9, 2022 01:03 PM
b1mcp
Aug 24, 2021 07:32 PM
mikega
Jul 21, 2020 05:02 PM
Jagboi64
Mar 16, 2020 08:49 AM
