Negitive rear camber and axle shortening
Old Jun 26, 2021 | 10:07 AM
ruffindustries's Avatar
Default Negitive rear camber and axle shortening
Hey Guys, I'm in the process of researching how to achieve the camber I want in the rear of my series 3. I know i can remove the shims for some adjustment but i don't think that will give me the degree I want. Sooooo, my thinking is to shorten the half shafts and machine a custom spacer to set the camber. I'm not 100% sure until I start playing with it but I'm thinking like 3-4 degrees. Any foreseeable issues? Reference below
Old Jun 26, 2021 | 10:11 AM
Also does anyone have any experience shorting the axles? Picture below shows one method. When doing this do you turn down both ends of the yoke and use a tube to achieve length, or do you only do one end and sleeve it? Thanks!
Old Jun 26, 2021 | 10:50 AM
Doug's Avatar
I'd say it's certainly 'doable'. I'd think any shop that specializes in shortening driveshafts can shorten your axle shafts, as their really nothing more than a short driveshaft. I'm a little uncertain about this as a DIY project. Balance and straightness issues come to mind.
Old Jun 26, 2021 | 10:52 AM
I agree with your concerns. I would defiantly be utilizing a machine shop for the fabrication work.
Doug's Avatar
Issues regarding the process of shortening the shaft? Or issues resulting from adding a lot more camber?
Old Jun 26, 2021 | 10:56 AM
I've never seen anyone run camber like that before on a Jag. On paper it sounds like the shortening the axles and adding spacers wouldn't really alter the way the camber is set originally correct? its just going to allow more adjustment. When I say issues i mean like possibly the bolts not being long enough to cater to the spacer or something to that effect.
Old Jun 26, 2021 | 11:06 AM
Doug's Avatar
As I see it, yes, correct
You'd probably need longer bolts, yes.
You're blazing the trail here.
Old Jun 26, 2021 | 11:20 AM
I figure I might as well keep going... current state of my rear setup.....
Old Jun 26, 2021 | 11:23 AM
Old Jun 26, 2021 | 03:01 PM
JagCad's Avatar
1. Cut the shafts. Aye, that sure would change the camber. i see the idea of shimss as a way to fine tune the degree of camber.
2. A drive line shop should have no issue at all with the project.
3. with a huge amount of luck and ingenuity, DIY might just do it.
3. A tale. Circa 52, a local had a nice 49 ford convertible. Not happy with the V8 in it. Fancied a Cad conversion that was popular. Alas a 332 CI OHV beyond his budget.
But, a 48 flat head Caddie and hydramatic was. Teh two drive shafts were cut, mted and welded on the shop floor. His uncle's shop. it worked !! Sorta. Now, a lot lower in front. The big Caddy was heavier than the Ford V8. it sounded great and according to the owner drove just fine.... ..
Old Jun 26, 2021 | 03:52 PM
motorcarman's Avatar
Is the point of that to look ridiculous/odd or is there a handling advantage?
(asking for a friend)
Old Jun 26, 2021 | 04:30 PM
If by ridiculous you are meaning ridiculously cool!? HAHA I'm sure someone would argue a function to it but I honestly just like it aesthetically. Different strokes you know.
Old Jun 26, 2021 | 07:52 PM
kezorm's Avatar
U-joints aren't going to be happy with that much camber. U-joints aren't constant velocity, so they need equal and opposite angle at each end to cancel each other out.
Greg
Old Jun 26, 2021 | 08:20 PM
mansterckp's Avatar
i do enjoy the negative camber, not sure on a xj6 though, not to mention the sheer number of tires you're gonna be burning through, don't forget how goddamn heavy these beasts are
Old Jun 26, 2021 | 10:10 PM
In a previous life someone set Nix's rear camber at -1 and welded it up.
Even one degree negative is noticeable, but it doesn't eat tires.
Only corners like it's on rails.
Old Jun 27, 2021 | 05:24 AM
redtriangle's Avatar
I say, gentlemen, don't you feel 3-4 degrees negative is rather excessive?
Nevertherless, I would like a little more NC on my LHS (all shims removed) so I like your thinking.
Old Jun 27, 2021 | 09:00 AM
I agree (although not being a Gentleman I have waited for Guys to say it first), 3-4 degrees IS excessive.
As I mentioned above, even 1 degree is noticeable. In these parts, only Boy Racers with 9 inch rims on Slammed Hondas set their camber so aggressively.
Old Jun 27, 2021 | 03:08 PM
JagCad's Avatar
Seems that way back a pretty fast NASCAR racer did the negative camber on his mid 80's Tbirds. Bill Elliott. Straight rear axle. Bent just a tad. Put the bearings in stress.
Stuck better on track. good enough for practice qualifying and 500 miles. good enough
It does countet the tendency to tuck a tire on the outside wheel in a tight turn. .
Old Jun 28, 2021 | 08:10 AM
I just threw 3-4 degrees out there not knowing what will look the best. I will be modest with her......
Old Jun 29, 2021 | 10:04 AM
kezorm's Avatar
Will mention it once more in case previous comment got missed. You may start to run into vibration issues if running much more than 1 degree. U-joints aren't constant velocity joints.
