New to forum
Old Feb 2, 2015 | 02:34 PM
1983turbojaguarxj6's Avatar
Default New to forum
Hey everyone, I have a 1983 jaguar xj6 sbc turbocharged. The car has been in the family since 84. Thought I would join to see some cool Jaguars.
Old Feb 2, 2015 | 03:17 PM
Roger Mabry's Avatar
Default Turbo pictures
Great, glad to have you with us.
How about posting some pictures of the turbo install? Any info on how it was done and brands etc.
Old Feb 2, 2015 | 05:22 PM
Jose's Avatar
Hi!
turbocharged? original engine? post pictures !
Old Feb 2, 2015 | 06:31 PM
Old Feb 2, 2015 | 06:36 PM
Stoney85's Avatar
impressive
Old Feb 2, 2015 | 06:41 PM
Cambo's Avatar
Please please please, more pictures!!!
Old Feb 2, 2015 | 06:52 PM
Old Feb 2, 2015 | 06:55 PM
Default Fantastic!
Any specs on the performance gained?
Old Feb 2, 2015 | 07:02 PM
420/620 rear wheel on low boost. We built the kit and we stopped on the dyno because the a/r on the turbo was wrong. Moved up to a billet Compturbo and haven't been back yet. It's a monster! I run boost by time with a AMS1000 boost controller on CO2.
Old Feb 2, 2015 | 07:33 PM
That is a thing of Beauty!
Welcome to our little corner of these forums.
Old Feb 3, 2015 | 05:38 AM
o1xjr's Avatar
Can you record the next dyno run, please,please,please....(with sound)
Old Feb 3, 2015 | 08:08 AM
icsamerica's Avatar
wow... really nice work and creative packaging. That Stealth Ram looks nice in there. I bet you were amazed it fit under the hood. How do you get it to hook. Any rear tire size mods? I have far less power and have traction problems. Were you able to keep the AC compressor? What heads?...what exhaust manifolds? What transmission? Ever run it at the track? I'm gunning for a F type coupe or time of 12.0 at 120 with my Chevy 406 project.
Old Feb 3, 2015 | 01:20 PM
I use drag radials in the rear. I run boost by time on my boost controller and use that to tune traction. I use a Godley th400 with a manual valve body and 2600 stall. Built forged motor. Holley efi standalone.
Old Jan 25, 2024 | 10:26 AM
Nylonpunk's Avatar
Wow! I just Twin Turboed mine and well it may be 10% faster? Not sure why? Did you cam your too? any suggestions will be humbly accepted.
Just joined 1984 XJS SBC stock with Twin ebay GT35 Turbos. Was expecting 400- 600 HPS think I am at 250?
Flow is good - Burns a bit ric
Old Jan 25, 2024 | 08:30 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Did you re-jet your carb after the turbos were installed? How did the engine run before you installed the turbos? Do a little research on the difference between "blow thru" and "draw thru" carburetor/turbo installations. The increased air flow and "blow through" setup without adjusting fuel metering in the carb could be causing your rich mixture. Look at your spark plugs to verify a rich/lean mixture.
Dave
Old Jan 26, 2024 | 07:33 AM
It could be a number of things, what’s your air/fuel ratio? Are the turbo’s sized correctly? Being twin turbo, it should be efficient and spool pretty quick.
Old Jan 26, 2024 | 07:38 AM
This is a more recent pic.
Old Jan 26, 2024 | 10:03 AM
LT1 jaguar's Avatar
The installation of Nylonpunk will need more carb attention (modification) and fuel/air tuning than an engine with fuel injection.
Dave
Old Feb 5, 2024 | 10:51 AM
Nylonpunk's Avatar
Dave
So yeah, I built my own blow through from a Holley Double pumper 850 CFM. Drilled bigger holes on the Metering block on under the power "buttons" (forgot what they were called) for boost and longer jets with nitrophl floats. I followed really good directions. I suspect the secondary float needled being stuck letting in extra fuel will check that. I will dig into the carburetor and rebuild it again in the coming months. It is running 11.5 at idle - 11.75 on cruise on the AFR - Not horrible but still on the rich side.
Installed 2 sets of smaller turbos .48 AR on the Turbine side/ .60 AR on the comprssor side - now I have compression on WOT and the blow through hiss after I let off the accelerator. My issuse is that the oil seeps into the turbo and the smokes at throttle. i have 40 - 45 psi on the oil pressure. So I put in oil restrictors and now thinking of lowering the oil level to reduce pressure to 30-35psi.
THANK YOU DAVE will certainly take a closer look at the Carbs.
Nylonpunk
Old Feb 5, 2024 | 10:57 AM
Nylonpunk's Avatar
Sorry Just seeing this now. So I reduced the Twin Turbos to .48 AR Turbine side and /.60 AR Compression side and now they have compression. Didn't do a highway test yet. but they feel good on local streets doing 50mph. Still not seeing crazy power. next is to see if I can get it properly tuned by a pro. This should be interesting. I like in Northeast NJ, Bergen county any one know a good old time hot rod SBC mechanic near me?
