Newbie looking at a XJ12
Old Oct 27, 2011 | 09:05 PM
Doug's Avatar
It's plausible. Over the years I've heard of some cases where a brake hose collapases internally and causes brakes to remain applied.
If the brake calipers, rotors, hoses etc are original....and considering 9 years of storage which plays hell with hydraulics (and other things as well).... I'd brace myself for a full system overhaul.
Be ready for gas tank rust as well, and replacement of fuel hoses, all new fluids and filters, etc as part of the recommissioning process.
For general buying advice thre's a Buyers Guide at the top of this section....in one of the sticky threads.
Old Oct 27, 2011 | 09:30 PM
perfectphoto's Avatar
That happened to my xk 150 with the bakes, not a hard fix I don't think you have to drop the rear end to replace, but not sure.
Old Oct 28, 2011 | 06:48 AM
Fraser Mitchell's Avatar
There is only a single flexible line on the rear brake line, connecting the pipes on the subframe with the pipe from the master cylinder. Whilst this could be collapsing internally, I suspect a stuck/sticky caliper piston.
I had a Series 3 like yours, (although the six cylinder engine), and had a rear caliper piston seize up and cook the seals. As Doug says, get ready for a lot of work. It would be best to replace all lines with cupronickel pipe, and brass fittings, and overhaul all calipers. The rear suspension is best done by first removing the whole rear subframe as there is little/no room to get at things with it on the car. It is not too difficult to remove, but you need a trolley jack with a fairly high lift, plus stands for the body to rest on.
trickeyM
Feb 29, 2020 07:00 PM
Msteiner
May 16, 2016 12:19 AM
MILOU13
Nov 25, 2015 02:39 AM
Clare Jennings
Oct 4, 2015 05:43 PM
