NO headlights this morning
Old Oct 15, 2009 | 05:49 PM
ken@britishparts.com's Avatar
The most common failure is the headlamp relay. Give it a loving tap with a rubber mallet and see if they don't come back. If they do, buy a new relay. It won't live much longer.
Old Oct 15, 2009 | 10:12 PM
Doug's Avatar
And clean all of the fuse clips as well as the nest of connections under the fusebox....corrosion takes a toll.
Old Oct 16, 2009 | 02:08 AM
tmz_99's Avatar
where is the headlamp relay???
Im also having problems with mine - the high beams *stick* on... :S rather annoying to other motorists Im sure..
Old Oct 16, 2009 | 08:25 AM
Doug's Avatar
The relay is between the master cylinder and the fuse box, yes.
Many have had good luck in opening up the relay and cleaning the contacts. However, if the plastic bits are melted, you're sunk
Here's more headlight info:
http://www.jag-lovers.org/xjlovers/xjfaq/headlamp.htm
Old Aug 23, 2010 | 04:57 PM
76xj12's Avatar
Good info, as this is one of my first tasks to tackle, no headlights or blinkers
GGabriel
Nov 22, 2018 03:53 AM
Jpav27
Sep 26, 2015 03:33 PM
Samheath100
Sep 17, 2015 10:03 AM
tsimms7
Sep 15, 2015 12:43 PM
laserguy
Sep 3, 2015 02:02 PM
