Nothing goes as planned!!!!
Old Dec 27, 2021 | 02:50 PM
Darrenmb's Avatar
Veteran: Navy
Default Nothing goes as planned!!!!
I was all set to drop rear out of car and do my gear swap, but car has other plans…… took it out for a
drive this morning to run a data log so I can
compare everything after the swap, but noooooo, got put to a Main Street where it is safe to do a little spirited acceleration, put foot down, hesitation and a pop, then bucked a bit, let off gas and applied normally and away she drove, turned around and went home, read the data and when I hit the gas she went instantly lean!!! A little
digging and both of my pre
filters are
about clogged solid!!! Guess I’m cleaning tanks instead of changing gears!!!! Never fails though, both tanks are of course full!!!!! Will post pics of all the crap I get out when I am
done!!!
Hope everyone had a merry Christmas, or whatever it is you celebrate!
Old Dec 29, 2021 | 03:56 AM
yarpos's Avatar
Well that has everything, planning and anticipation, unexpected problems, delayed gratification, a hint of despair and all with a fine dusting of Murphys Law full tanks; and we tell ourselves we do this for fun
Old Dec 29, 2021 | 09:26 AM
You don't see the Fun in this, Steve?!
I see a Lot more Fun in this than in some things I have to do.
Old Dec 29, 2021 | 09:50 AM
Doug's Avatar
filters are
about clogged solid!!! Guess I’m cleaning tanks instead of changing gears!!!! !
Welllll......
Are you gonna remove the tanks? Not a pleasant task.
There is an option that might work. It has worked for others.
Replace the pre- filters and drive the car. They'll clog again. Replace them again; they'll clog again....but probably not so quickly. Repeat, repeat, repeat. With a bit of luck all the loose crud will be captured after 4-5 times and you'll be on your way.
Just a thought.
Old Dec 29, 2021 | 11:13 AM
Darrenmb's Avatar
Veteran: Navy
I have the cleanable filters, so that’s not a big hassle, I have cleaned the filters out, pumped the gas out of right tank into fuel Jugs and have just shot a pressure washer wand up I. From tail light, the amount of crud that came out is unbelievable!, it’s currently airing out and I amusing my compressor to force air in too! If this works, I will move to the left tank,
Crud from pre filters
Crud from tank( not the leaves) lol
In tank filter/sock
Old Dec 29, 2021 | 11:48 AM
JagCad's Avatar
My codicil to Murphy! //// and once having gone wrong will remain so.
Old Dec 29, 2021 | 08:29 PM
lickahotskillet's Avatar
Doesn't look like a drive and replace scenario. How old are the tanks? I tried to clean mine and gave up. Bought new ones.
Old Dec 30, 2021 | 03:29 AM
Peter3442's Avatar
Been there! In the end, we not only replaced the tanks, but also all the fuel lines and the changeover valves. And had the injectors cleaned twice.
Old Dec 30, 2021 | 06:59 AM
Darrenmb's Avatar
Veteran: Navy
Tanks are original to car, so 38 years old, the odd part is, when I looked inside gas tank, it was only cruddy on the bottom, side walls looked quite nice, just a goldy looking tarnish ( for lack of a better description) if new tanks are in my future, so be it, it’s just nuts and bolts, probably the only ones I haven’t touched yet! Lol
Old Dec 30, 2021 | 03:54 PM
sanchez's Avatar
Scary! I am going to take a look at my pre-pump filters and replace them. I have been running my car everyday for the last 5 years with no problems. My tanks were steam cleaned in 2015.
Went to NAPA and bought 2 pre-pump filters. I have a new post pump filter in my garage so I will replace all 3.
Thank you for sharing your pics. Made me wake up to what can happen with all the sand we have here in Florida.
Old Jan 8, 2022 | 10:15 PM
Cabel's Avatar
I had mine boiled out by a radiator shop then lined. He told me that he removed about 15 lbs of sludge and rust between the two tanks. That's not something you are going to be able to fix by just changing filters.
amcdonal86
26
Mar 25, 2017 09:12 AM
Uncle Fishbits
Dec 16, 2016 08:23 PM
Johnken
Feb 12, 2015 08:17 AM
WinterJag
27
Jun 5, 2011 08:37 PM
hughey
Sep 6, 2009 01:27 AM
