oxygen sensor idiot light...
Old Mar 12, 2018 | 08:06 PM
Doug's Avatar
Originally Posted by JayJagJay
I meant the kill switch for the 02 sensor...
Never heard of a kill switch for an O2 sensor.
Could you give some more detail?
Old Mar 13, 2018 | 09:24 AM
JagCad's Avatar
Check the XJS forum. Different engine management systems. It may not have a counter for O2 service.
And, the nomenclature thing. Not a kill switch at all. merely, a reset button.
Off to SMOG my Jaguar today .
Carl
Carl
Old Mar 13, 2018 | 11:14 AM
JayJagJay's Avatar
Hi, yeah, sorry about the language...
Yes, a reset switch. To turn off the dash light. I had/have heard that there is a switch or a button, in the trunk in some, what is actually a mileage counter and at 30,000Mi it lights the switch reminding of regular service. I have checked my trunk and haven't seen this thing. Any help would be a great, help
Old Mar 13, 2018 | 11:40 AM
Doug's Avatar
Not for your 1990.
The reset capability mentioned in this thread was for older models....roughly 1986-earlier
Old Mar 14, 2018 | 08:57 AM
Dutch-Cat's Avatar
Boy am I glad the european versions don't have this ****....
Old Mar 14, 2018 | 02:33 PM
Jose's Avatar
North American cars are loaded with it.
Old Mar 14, 2018 | 04:39 PM
new mexico's Avatar
Default oxygen sensor
Originally Posted by ronin
Hey, took a decent length trip in my '86 XJ6 this weekend, ~5 hours one way. No issues on the way there. As you well know, it did great on the highway. I ran between 70~80 mph most of the time. On the way back the Oxygen Sensor light came on. Does this truly mean my oxygen sensor is bad, or could it it also mean something else?
Car has ~116K miles on her, and I don't know if the sensor has ever been replaced. Car didn't seem to run any different after the light came on, and she delivered me back home with no issues. All aux. gauges looked normal.
As always, thanks for the help,
Eric
Get a new sensor anyway.
Walter
Old Mar 15, 2018 | 11:10 AM
  #28
JagCad's Avatar
Oh, h.... yes !!!
My lumped 83 just passed CA Smog test !!!!
Carl
Old Mar 16, 2018 | 09:59 AM
JayJagJay's Avatar
Hi Doug...
Undderstood. Any suggestions about reseting later models? Any suggestion will do. Is it just a matter of replacing and it will "reset" itself? That sounds too good, AND, too bad to be true, lol
Old Mar 16, 2018 | 10:09 AM
  #30
Doug's Avatar
Hi Doug...
Sorry, no. Nothing definitive, at least. I just not familiar with the systems used on the later XJS.
Sometimes just disconnecting the battery will clear warning lights or trouble codes.
On other cars, disconnecting both battery cables and touching them together does the trick.
If the warning light/message is displayed because the system detects an *actual fault* then replacing the faulty sensor might eventually extinguish the light, as the system will recognize the absence of the fault and turn off the light after xxx-number of driving cycles. I doubt it, as I don't think the systems of that vintage an do that....but maybe.
I'd post the question of the XJS. Someone will know the answer
Old Mar 16, 2018 | 10:12 AM
  #31
Doug's Avatar
It's a curse and a blessing.
Lambda systems are generally considered a good thing as fueling is more precisely controlled.
The downside, of course, is more systems = "more to go wrong" !
Old Mar 16, 2018 | 10:23 AM
  #32
JayJagJay's Avatar
Yup, yes, maybe and YUP! lol,,,
Thank you Doug!
Old Jan 29, 2023 | 02:25 PM
  #33
wagonerkl's Avatar
In the boot looking forward with panel removed.
Correct plunger is circled on the left. I was fumbling with the white protrusion on the right; obviously with no effect.
Thanks to John_Cook12 for the photo; it got me in the right area but I found myself fumbling with the wrong "plunger" for a bit. Here are a couple shots that will hopefully prevent that for someone else. Mine is an '86.
Last edited by wagonerkl; Jan 29, 2023 at 02:28 PM. Reason: photo file not attached
meirion1
Nov 26, 2022 03:47 PM
J8levi
Jan 3, 2015 08:53 PM
nellycolts
Jun 27, 2014 06:15 PM
stellar-warior
May 19, 2013 05:37 PM
Johnw
May 29, 2011 11:17 PM
