Power Steering Issue
Old Aug 6, 2015 | 11:21 PM
larney's Avatar
Default Power Steering Issue
The power steering is leaking in my friends 87 XJ6. He said it was leaking form the rack/pinon. Are these difficult to replace? Are we looking at major removal or is this a simple(sort of) bolt off/bolt on?
Larney
Old Aug 6, 2015 | 11:50 PM
Doug's Avatar
Simple (sort of) remove-and-replace job. It's not a pleasant job but, in a brief nutshell
- separate tie rods from the steering arms
- separate steering column coupler from rack
- remove hydraulic pipes/hoses
- remove three bolts that hold the rack in place
- reverse steps to install new rack
It's awkward and clumsy, and dirty....especially if working on your back.... but certainly DIY-able
Old Aug 7, 2015 | 06:52 AM
Jose's Avatar
while you're at it, replace the rubber bushes with John's Cars polyurethane bushing kit to eliminate the side-to-side movement of the rack typical in these cars. Assuming it hasn't been done already.
in the following link you can read some tips about rack removal:
Steering Rack Bushing Replacement
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
