Power Window Fuse Location?
Old Jul 3, 2013 | 08:10 PM
mgmidgetbill's Avatar
Default Power Window Fuse Location?
Just bought a 1970 XJ6 and after correcting some bad switches in the dash I find that none of the power windows work. I have checked the schematics but can't find the location of a fuse or circuit breaker for the windows, anyone have any ideas?
Old Jul 4, 2013 | 01:09 PM
marvin1960's Avatar
So...keep in mind that my experience is with a 1987 XJ6. On my car the fuse panels are under the dash, one panel on each side. The head light panel is under the hood, drivers side, midway towards the front.
The 87 XJ6 has the fuse listings on the fuse panel access door. For some help on this, you may want to go to www.captainjaguarscathouse.com They have free electrical downloads. It's where I found mine.
Old Jul 5, 2013 | 10:32 AM
davidboger's Avatar
The Control Unit for the Series 1 is under the kick panel, in the left hand foot well. You'll have to remove the kick panel, under the pull out vent, to access it.
A lot of the time this is an area that gets water in it, and the control boxes either rust or get bad connections...
Here is a photo of the part you are looking for...
(The actual fuse panel on the car is behind the gauges. They are accessed by removing some thumb screws on the front. The whole gauge panel hinges forward. None of these fuses are tagged as having any bearing on the windows, though)
Cheers,
David
Everyday XJ
Old Jul 19, 2013 | 12:44 PM
marvin1960's Avatar
Hey David, do you have a similar diagram for a series 3 XJ6?
Old Jul 19, 2013 | 02:29 PM
JagCad's Avatar
Check captainjaguarscathouse website for the S57 diagrams.
Failing that, contact e for the page you need PM. I've shared more than once in appreciation for the Jag over that shared with me.
Carl
Old Jul 19, 2013 | 06:08 PM
marvin1960's Avatar
Thanks David, I'll check captains site. I've visitied it a number of times.
Old Jul 19, 2013 | 06:39 PM
CATPart's Avatar
Well on my dad's '72 those window motors died one by one. It was a high mileage car when that happened. I just picked up a '73 with only 37k on it and all 4 windows work, I was very happy.
Old Oct 13, 2015 | 03:06 PM
pricebill's Avatar
Default apologies from bringing an old thread to life
All four of my windows died. 1972 Series 1 XJ6. The right rear was dragging and I believe it tripped the circuit breaker. I found the relay behind the kick panel and opened it up to reveal two relays and a circuit breaker. Is there any way to reset the circuit breaker or am I replacing it with a 30amp fuse?
Old Oct 13, 2015 | 09:46 PM
pricebill's Avatar
Default never mind
Circuit breaker was easily replaced at my local parts store for $2.34. Two small bolts and windows are working well again. Here's a picture of the inside of the series 1 window control unit. Two relays and a circuit breaker. Might help someone in the future.
Old Oct 14, 2015 | 08:42 AM
Jose's Avatar
in the Series 2 and maybe Series 3, there is a Power Window circuit breaker (I believe) to the right of the passenger side fuse box, under the dash. you have to remove the under-dash Panel to see a number of components there.
I have never messed with it so I am not 100% on this, just posting it in case someone else is familiar with it. The picture below is a Series 2 XJ-6.
Attached Thumbnails Power Window Fuse Location?-xj-6-under-dash-switches.jpg
Old Oct 29, 2015 | 02:39 PM
Bob Kontak's Avatar
77 XJ-12
Have been wrestling with driver's window switch for a long time now. Cleaned contacts, etc. Intermittent.
Swapped it with another switch. Blew a fuse, breaker or cooked a relay, I believe.
Can't find location or any to save my rear. Looking for thermal breakers.
Kick panels, behind counsel vents, under dash, under glove box. Nothing.
Below is my Series 2 RHS which I think is the same location as Jose's goodies pictured above.
Factory manual I think shows thermal breakers and a relay but no location.
EDIT - HOLD UP - JUST FOUND SOMETHING THAT I THINK IS GOING TO BE DELIGHTFULLY EMBARRASSING. Watch this space...........
Old Oct 29, 2015 | 04:04 PM
Jose's Avatar
Bob,
take a picture if you find it !!
Old Oct 29, 2015 | 04:29 PM
Doug's Avatar
Look under the rear seat. I think Series IIs have some relays there....not sure
The pic Jose put up is a Series III. Surely similar in some ways but probably different in others.
Old Oct 29, 2015 | 05:12 PM
Originally Posted by Doug
Look under the rear seat. I think Series IIs have some relays there....not sure[...]
I had my whole entire rear seat disassembled and out of the car recently, there were No relays anywhere in the area, nor any evidence there ever had been any.
Old Oct 29, 2015 | 06:55 PM
Bob Kontak's Avatar
No dice. The power wire to the electric door locks switch had come loose. Thought it may have fed the windows.
I did find where I wired the window switches wrong based on pictures I had taken.
Back to square one. Bummer.
Old Oct 29, 2015 | 07:06 PM
I'm dealing with the same problem. I took the console apart last winter and was *Very* careful to make a map of the back of all the switches. When I put it all back together, NONE of the windows work!
I haven't gone back in to see what I did wrong, so I'm watching this thread closely too see if you might also have a hint where I could look when I get to it.
Old Oct 30, 2015 | 10:08 AM
Jose's Avatar
The pic Jose put up is a Series III. Surely similar in some ways but probably different in others. Cheers DD
that is not correct, it is a picture from a 1977 Series 2 from Jag Lovers from our Italiano friend.
Old Oct 30, 2015 | 10:13 AM
Doug's Avatar
Remember that our Italiano friend had both a Series II and a Series III
Note the cruise control module.
Series II cars did not have cruise control. Series III cars did.
PS:
Here's the original photo array, clearly marked as "Series III"
http://www.jag-lovers.org/snaps/snap...?id=1157149498
Not trying to pick nits. Just don't want Series II owners wasting time looking for things based on a Series III photo
Old Oct 30, 2015 | 12:59 PM
Bob Kontak's Avatar
Looks like an "oops" made in good faith.
The panels are pretty easy to take off so no time wasted. Especially the glove box one.
Old Oct 30, 2015 | 01:08 PM
Doug's Avatar
I understand. And my attempts at providing good information and correcting mis-information are likewise in good faith.
No harm meant.
