Question about dashboard gauges
82 xj6 series 3. Im not sure how the gauges on the dash are all connected. Are they all connected to one main source? The odometer hasn't been working since I got the car, the speedometer wobbles when it hits bumps then works when I accelerate (tried to rotate it out of the spring still cant get it). The coolant gauge I notice likes to go from a little under halfway then steps a hair down when accelerating, oil gauge works fine, the voltage meter im suspecting is faulty and causing that battery light to stay dim. I hooked up the multimeter to the terminals and turned on all the accessories, reved the engine a bit and it stays around 13.8-14 volts. But in the morning I notice when I hit about 40-45mph the volt gauge like to creep up a little under the red zone but will never hit the red zone.
